Author: Subject: potterton ep2002?
aka Keith
posted on 3/9/10 at 07:36 PM Reply With Quote
potterton ep2002?
in the last couple of weeks my potterton ep2002 controller keeps blowing fuses in the plug. Anyone any ideas as to why?
Craig
Daddylonglegs
posted on 3/9/10 at 08:32 PM Reply With Quote
'cos it's too early to put the heating on, It's only September so the boiler say's NO!
goaty
posted on 3/9/10 at 10:58 PM Reply With Quote
sometimes they breakdown internally. replace it and it prob solve the issue.
are you sure its the programmer though and not the valve? when exactly does it do it?
goaty
posted on 3/9/10 at 10:59 PM Reply With Quote
mangogrooveworkshop
posted on 4/9/10 at 05:27 AM Reply With Quote
Its cause its a potterton
Ive got a BAXI ANTARTICA the model formerly known as the Barcelona. Worst brand ever
Have you got the schematic?
lewis
posted on 4/9/10 at 07:29 AM Reply With Quote
The circuit board is a common fault on those they are on mk6 at the mo!! Just had ours replaced last month,a resistor burns out and causes all sorts of different symptoms/problems it cost us £320 with a service :-(
lewis
posted on 4/9/10 at 07:30 AM Reply With Quote
How do you think he gets hot water doughnut ;-)
goaty
posted on 4/9/10 at 03:00 PM Reply With Quote
programmers are only cheap to replace, just clips on and off too. no wiring if straight swap.
aka Keith
posted on 5/9/10 at 11:01 AM Reply With Quote
Thanks everyone. replaced the programmer unit and it still randonly blew a fuse in the plug a couple of hours later.
Works fine if hot water only, seems to blow a fuse only when set to do hot water and central heating.
I think that it may be the motorised valve, that is causing the overload.
next job to be done, I take it.
cheers
Craig
