zilspeed
posted on 4/9/10 at 04:52 PM |
Data Logging
Anyone out there run any form of data logging ?
We're interested in investigating what's available for various projects which are ongoing and would be interested to hear the views of
anyone who has used it, be it home brewed or off the shelf.
Being renowned as being a wee bit tight, I'm obviously more interested in a home brewed solution.
What's available ?
What software do you use to analyse the results ?
How much does it cost ?
JF
eddie99
posted on 4/9/10 at 04:56 PM |
Hi
Im also very interested to hear the responses on this thread. So far at the cheaper end of the scale, i've only found etb and race tech but they
are far from cheap...
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
athoirs
posted on 4/9/10 at 04:59 PM |
Is this to measure rebuild time John...(he! he!)
zilspeed
posted on 4/9/10 at 05:20 PM |
Nah.
A ten year calendar will do for that.
Yah barsteward.
Any roads, I did more today.
If a job's worth doing, it's worth doing slowly and badly.
No, this is for an associate.
The Race Technology DL1 seems pretty comprehensive.
irvined
posted on 4/9/10 at 07:25 PM |
I bought a digidash which has logging for the fury, it has plenty of channels, logs at a reasonable rate, and the analysis software is pretty decent,
it does mapping and can do some video overlay too.
For the locost i rolled my own, the plan is to use a tomtom to do the logging itself, but for now I use a laptop until i've got the rest of the
software working right. It uses a bunch of USB sensor dongles to pull analog data, and a serial dongle connected to megasquirt to dump out engine
metrics.
Visualization i'm using a combination of excel and paraview.
http://irvined.blogspot.com
loggyboy
posted on 4/9/10 at 07:39 PM |
Are you talking about logging engine data or car movement data?
If the latter then try racechrono.com and you will need a GPS enabled phone (nokia or windows based IIRC)
If the former, then the etb digidash at £400 would be ideal. and you wont get much cheaper than that i doubt.
RK
posted on 4/9/10 at 10:36 PM |
veypor does the datalogging of car movement for quite cheap. Uses accelerometers.
zilspeed
posted on 5/9/10 at 07:55 AM |
In repsonse to the last couple of posts, it's pretty much all of it.
Accelerometer to measure braking effect.
analog input to measure brake line pressure to tie in with the above.
This would be an example of the type of thing we're interested in.
engine data will be based on a carbed engine with a dizzy, so fairly limited.
GPS for track position, we're not so sure about at this point.
It's really about being able to analyse what the car is capable of doing and then assessing how the driver is putting that capability to use.
Thanks for the input so far.
TimC
posted on 5/9/10 at 09:35 AM |
In a cafe in Amsterdam? Sorry, couldn't resist.
