Author: Subject: C20XE to Type 9
SALAD
posted on 7/9/10 at 11:59 AM Reply With Quote
C20XE to Type 9
Just need a couple of part numbers....
OK, list of required parts as I understand it:
Standard XE Cover Plate (Pressure Plate) - Early or late type dependent on what flywheel used.
Sierra 2.3 Diesel Friction Plate (Driven Plate) - Or another 23 spline plate (Check thickness).
Standard Sierra / Ford Release Bearing - QH CCT132??
RS2000 Clutch Fork
Vauxhall Spiggot Bush / Bearing - NUMBER??
Capri Short Adjustable Cable.
SBD / QED / Yukspeed Bellhousing.
Can anyone confirm the Ford release bearing number and let me know the Vauxhall spiggot bush / bearing number please?? I have most of the other bits.
ruudbeckers
posted on 7/9/10 at 03:41 PM Reply With Quote
I decided to go for a hydraulic clutch, so I have a clutch fork and release bearing for sale. I did fit it to my car, but I am still building it so it has zero miles on it. I bought it from Yukspeed for 57 pounds. You can have it for 35 pound posted to the UK.
joolsmi16
posted on 7/9/10 at 04:11 PM Reply With Quote
c20xe
Hi if you ring Yuk at Yukspeed on 01653618540 just ordered all the bits for mine. very helpful guy and good prices.
Also stevegough may be along in a bit to answer all questions.
Jools
SALAD
posted on 7/9/10 at 05:35 PM Reply With Quote
Thanks chaps but I already have the fork and I have ordered other bits from Yukspeed and he is a good bloke to deal with but I just need the correct part numbers so I can go to my local motorfactors and pick up the bearings / bushes.
joolsmi16
posted on 7/9/10 at 06:06 PM Reply With Quote
c20xe
Try this link for all part No.s http://westfield-world.com/xeparts.html
Jools
SALAD
posted on 7/9/10 at 07:38 PM Reply With Quote
Good link Jools!
Still not sure of the Vauxhall Spigot bearing number but that is a useful site.
Thanks.
stevegough
posted on 7/9/10 at 09:05 PM Reply With Quote
Link for spigot bearing - QED motorsport
QED
Link to SBD site - spigot / release brg / arm
SBD
Sorry, Not sure of actual part numbers. - Got my clutch from Yuk. - I have heard the one about the 2.3D, too but not sure if it is correct - told Yuk T9 to C20XE and he supplied the right one. Be careful - I ended up buying quite a few bits which proved hearsay to be sometimes infuriatingly wrong.....
Just remembered - I have a new spigot bearing if you want - £6 posted.
Any more questions, ask away!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
