Chippy
| posted on 9/9/10 at 10:19 PM |
MS After Start Enrichment??
Quick question for the MS guru's. In More Cranking Stuff, Extra Fuel For Cranking. 1st line says "Use First Start
Enrichment", with a little box with either YES or NO, (mine is currently NO), is this correct? Thanks in advance, Ray
BenTyreman
| posted on 9/9/10 at 10:38 PM |
IIRC, 1st start enrichment is triggered by pumping the throttle past flood-clear throttle position 3 times before cranking. It gives extra cranking
enrichment for when you think it needs a bit more help (i.e. on the 1st start of the day). Only needed in unusual circumstances (particular engine
and/or climate), so NO is usually correct.
ashg
| posted on 10/9/10 at 07:49 AM |
if it starts without any bother leave it well alone.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
fatbaldbloke
| posted on 10/9/10 at 07:32 PM |
As above, shouldn't need it. I have mine set to on but haven't activated it (3 full throttle presses) ever since I fitted TB's.
Chippy
| posted on 10/9/10 at 10:12 PM |
Cheers guy's, thats one more thing I don't need to worry about then, Cheers Ray
