chunky2772
posted on 11/9/10 at 10:12 PM |
steering damper question!
when fitting a bike engine in a car if you leave the steering damper sensor plug loose i,e not connected to anything does the ecu read any faults
engine is a k8 gsxr. thanks.
cosmick
posted on 13/9/10 at 05:17 PM |
You will need to replace the steering damper with a 12ohm resistor of about 10 watts capacity. Without the resistor, if you are using the Suzuki
speedo, it will show an FI fault all the time.
If it can't be fixed with a hammer then its probably an electrical problem.
chunky2772
posted on 13/9/10 at 08:42 PM |
thanks for that mate will pop down to maplins the weekend (these newer engines are a bit of a pain wish i had of gone for somthing older now!)
cosmick
posted on 13/9/10 at 08:45 PM |
No you won't when you get it going. They fly
