Author: Subject: Fuel sender hole size
i_froloshki
posted on 12/9/10 at 07:36 PM Reply With Quote
Hi guys, i am going to order a fuel tank to a friend of mine who is wirking with stainless steel but i need to know the size of the hole that we need to make for the sender. It will be very helpful of you tell me the most common size so we can lazer cut it. Thank you very much in advance.
Yavor
i_froloshki
posted on 13/9/10 at 12:28 PM Reply With Quote
anybody?
40inches
posted on 13/9/10 at 01:50 PM Reply With Quote
I had a 50mm hole cut on my tank, two senders I had fit OK, lucky? who knows? Logic dictates that you buy the sender first, or check the dimension with the supplier.
