New Topic New Reply
Author: Subject: Anybody seen this chassis setup ? Help
thenorthface
posted on 13/9/10 at 02:48 PM Reply With Quote
has anybody seen this front end done on a chassis before ? I bought the chassis last week and all I know it's been modified to suit a R1 bike engine but I have noticed the front wishbones plates are they same top and lower (232mm) between the wishbone plates. The rear wishbones have been done to the haynes roadster spec
Will this front setup work ? If so does anybody know where I can get the front wishbones done ? Help please
big_wasa
posted on 13/9/10 at 03:03 PM Reply With Quote
In my opinion the steering rack mounts need beefing up a bit.
thenorthface
posted on 13/9/10 at 07:43 PM Reply With Quote
the steering rack has been made the same as the haynes roadster, what you think about the wishbones plates being the same ? has the builder copied another locost chassis ?
interestedparty
posted on 13/9/10 at 08:28 PM Reply With Quote
Looking at it, I'm guessing that the bottom brackets are as close together as the tops, which are standard (I don't have my Haynes book handy).
If that is the case, then I would say that is a bad thing. I don't know for sure, but intuition tells me that it's the bottom wishbones which take a lot of the reaction stress from braking, and that having narrow wishbones is a BAD thing.
thenorthface
posted on 13/9/10 at 08:36 PM Reply With Quote
That's what I was hoping people wouldn't say being a BAD thing !
Badger_McLetcher
posted on 13/9/10 at 09:08 PM Reply With Quote
Yep, the bottom wishbones react most of the braking forces.
If disfunction is a function, then I must be some kind of genius.
Mix
posted on 14/9/10 at 03:49 PM Reply With Quote
Hi
Just to put this into perspective, (as I understand it), a Cortina upright will transmit the braking load in the order of 56% to the lower bone and 44% to the upper.
Regards Mick
[Edited on 14/9/10 by Mix]
thenorthface
posted on 14/9/10 at 04:41 PM Reply With Quote
Does that mean with cortina uprights it will be ok to have the wishbones the same width upper and lower ?
Mix
posted on 15/9/10 at 04:08 PM Reply With Quote
Hi
I would be trying to determine what the chassis is. Are you going to make your own wishbones? if so I'd rejig the chassis to either the Locost or Haynes design and fit the relevant wishbones. Far too many unknowns to give a better response - sorry.
Regards Mick
Badger_McLetcher
posted on 15/9/10 at 05:19 PM Reply With Quote
That's not quite the correct question- it doesn't matter if the upper wishbone mounts are narrower, larger or the same as the lower, as long as the lower mounts are man enough to take the forces. Also you'll end up with some funny looking upper wishbones but hey
New Topic New Reply
