Jaybeee
posted on 13/9/10 at 10:55 PM |
Setting the Rear Suspension
Does anyone know what the measurement is to set the ride height on the rear suspension?
bonesetter
posted on 14/9/10 at 07:44 AM |
Bit higher than the front...??
snapper
posted on 14/9/10 at 06:02 PM |
If the chassis brackets are positioned correctly, the front should be lower when front and back bottom wishbones are parallel if not then the rear, as
said, should be higher when fully loaded.
Apparently the back lower than the front can cause all sorts of wayward handling
I eat to survive
I drink to forget
