Author: Subject: reverse light question for iva?
chunky2772
posted on 25/9/10 at 08:38 PM Reply With Quote
do i need a reverse light fitted to my bec for iva test my reverse is electric? also where should this be mounted (do i mount in the center at the rear on the car)
blakep82
posted on 25/9/10 at 08:45 PM Reply With Quote
its all in the manual
link below
but, yes, you do need one. has to be either automatically switched on when reverse is selected (not really practical on a electric reverse system) or come on with a switch, in which case it MUST have a tell tale warning light
________________________
chunky2772
posted on 25/9/10 at 08:52 PM Reply With Quote
my build is a locost so which one should i be looking at? what class does a kit car come under havent got a clue what im looking for!
[Edited on 25/9/10 by chunky2772]
blakep82
posted on 25/9/10 at 09:00 PM Reply With Quote
its the M1 one you will need mate
adithorp
posted on 25/9/10 at 09:02 PM Reply With Quote
link below
Why is it not practical? Take the feed for the light from the same switch as the reverse. Seperate switch is just complicating things (additional switch and warning light to wire up).
http://jpsc.org.uk/forum/
jack_t
posted on 25/9/10 at 09:03 PM Reply With Quote
reverse light is easy on the electric reverse
just power it from the the 12v trigger to the solenoid for the starter motor
so when u press the button to engage reverse it comes on
problem solved
chunky2772
posted on 25/9/10 at 09:07 PM Reply With Quote
thanks for that lads will look now cheers.
big_l
posted on 26/9/10 at 07:13 AM Reply With Quote
What about when you have a mnr reverse box ??? I've been struggling to get my head round mine ?????
Check out my blog mnrvortxhayabusa@blogspot.com
Pezza
posted on 26/9/10 at 11:13 AM Reply With Quote
I've mounted a micro switch under the lever, i'll grab a pic when I can.
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one portion of chicken tikka pwnsala and the obligatory free pwnpadom.
Pezza
posted on 2/10/10 at 01:39 PM Reply With Quote
seems to work nicely
