Author: Subject: Bike Carb Trumpet Angle
locosaki
posted on 30/9/10 at 07:21 PM Reply With Quote
I've got bike carbs fitted to my engine on a bogg manifold, Now when I fit my trumpets on they stick through the bonnet due to the angle of the carbs on the manifold.
The trumpets just push into a bit of rubber on the original airbox so if I fully push the trumpet in at the bottom and half slip it at the top into the rubber connector I then get the trumpets sitting level and under my bonnet (which I want)
Now I'm wondering due to the change in angle will this affect air flow into the carbs ?
jacko
posted on 30/9/10 at 07:31 PM Reply With Quote
If the trumpets are that close to the bonnet how are you going to fit a air filter ?
what carbs are they ?
SPYDER
posted on 30/9/10 at 07:59 PM Reply With Quote
Like Jacko says, if you have no air filter it's not the air flowing into the carbs that you need to be concerned with!
It's everything else flowing in!
locosaki
posted on 30/9/10 at 08:00 PM Reply With Quote
There ZX9r carbs, If I stick a filter on with the trumpets angled it clears the bonnet just I'm just unsure if tilting the trumpets down a little would cause problems ?
r1_pete
posted on 30/9/10 at 08:01 PM Reply With Quote
Agree with Jacko,
You should have 1.5 x the choke diameter between the end of the trumpet and any 'obstruction' e.g. airbox lid, filter plate etc.
jacko
posted on 30/9/10 at 08:12 PM Reply With Quote
Don't forget you want cold air into the filter hove a look in my photo archives the section zx9r carbs / manifold it may give you some ideas
Jacko
locosaki
posted on 30/9/10 at 08:18 PM Reply With Quote
I have the correct distance from filter to trumpet and with the trumpets angled down that puts them right at the back of the grill directly into the airflow.
jacko
posted on 30/9/10 at 08:43 PM Reply With Quote
It sounds like that will be ok do you have any photos of the engine / engine bay ?
Jacko
locosaki
posted on 30/9/10 at 08:50 PM Reply With Quote
I don't at the minute but could certainly take a few tomorrow to give you an idea.
I was just concerned that the angle of the trumpet going to the carb would disrupt the airflow maybe cause turbulance in saying that the fuel supply should still be spot on as the carbs mate to the manifold perfectly so really shouldn't get fuel drop out !
Angel Acevedo
posted on 1/10/10 at 01:02 PM Reply With Quote
Is cutting a couple of mm possible,
Diference in performance may not be noticeable at all,
But reading Carroll Smith Tune to win,
Every difference counts, so you may be looking for another solution, maybe a small scoop will give you colder air and a little bit of ram air pressure.
HTH
JF
posted on 2/10/10 at 11:08 AM Reply With Quote
Don't worry about ram air... it more an advertising tool then anything else.
It just adds a few hp at top speed, if done well...
