Author: Subject: Megasquirt base map
onslack
posted on 4/10/10 at 12:19 PM Reply With Quote
Megasquirt base map
Afternoon guys,
i wonder if your able to help me
i dont actually own a kit car but after searching on google i found your forum so signed up
i own a mk2 fiesta with a 2.0 zetec engine, i have recently got my megasquirt ecu back and i have been searching high and low for a base map to get my car up and running!
ive used the search function on here a few times and not found anything so thought id stick a thread up in the hope that someone might be able to help me out
i have a MS1 V3 Ecu, running all standard ford sensors
hopefully someone can help me out
cheers for your time
Terry
oadamo
posted on 4/10/10 at 03:40 PM Reply With Quote
best to ask on here everything you need to no.
adam
http://www.msextra.com/forums/index.php
posted on 4/10/10 at 03:46 PM Reply With Quote
Hi Terry, welcome. Theres no real 'base' map as such as all the different engine characteristics and sensors have to be taken into consideration.
I used a known Megajolt map for the ignition and constructed the start map from the instructions in the Megamanual.
Phil at MSextra may be able to help you though.
onslack
posted on 4/10/10 at 03:55 PM Reply With Quote
thanks for the replys guys, i'll have a check on there and drop phil and email and see what he can help me with
David_17
posted on 4/10/10 at 04:47 PM Reply With Quote
Check your u2u messages
onslack
posted on 4/10/10 at 04:55 PM Reply With Quote
Cheers for the u2u David!
Never thought to look there!Lol!
goaty
posted on 20/10/10 at 04:53 PM Reply With Quote
hey Terry, how this goin??
not spoken for a while, i see you still woring on the fez....got the saph fixed yet??
onslack
posted on 20/10/10 at 08:48 PM Reply With Quote
hey hey Joe,
fancy seeing you on here! yeah not seen you in a while
yeah the fez has gone a little crazy and not a sensible daily driver as i intended it to be
umm... not quite, the saph is still in bits, mainly because i have been distracted by the fez
