Author: Subject: perspex windows
tcr
posted on 11/10/10 at 09:06 PM Reply With Quote
perspex windows
while the 7 is asleep for the winter im starting my mk2 scirocco gti trackcar, one thing im gonna do is replace the glass with perspex .
Q1 will 4mm be thick enough or too thick for the side and rear windows ?
Qb as the rocco has a curved rear screen how easy is it to reproduce this shape without warping the plastic ?
MK MIDI ZX10R
http://www.facebook.com/media/set/?set=a.4393256076054.2182513.1427988207&type=1&l=64c91c3c17
why isnt anything simple!!!
torquetune.co.uk
nrpexhausts.co.uk
loggyboy
posted on 11/10/10 at 09:09 PM Reply With Quote
General idea is to use Polycarbonate, not perspex as perspex shatters. 4-6mm is what is generally used.
Curves in more than one direction are near impossible to create, in one direction is possible, maybe if you heat it or use narrower sheet (and risk it bowing on the wider sections) you may get a curve, but the base of the mk2 rear screen is fairly extreme.
[Edited on 11/10/10 by loggyboy]
mattyc
posted on 11/10/10 at 09:18 PM Reply With Quote
i have a vauge memory that if you warm it up in diesal it will become plyable and mold to a shape.
tcr
posted on 11/10/10 at 09:19 PM Reply With Quote
i only looked into perspex as its about £10 cheaper per sheet
my idea was to rivit along the top and sides then use a heat gun and scafold pipe to form the bend then rivit the bottom whilst still soft
[Edited on 11/10/10 by tcr]
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
austin man
posted on 11/10/10 at 09:23 PM Reply With Quote
hot air gun can be used to bend it ensure you keep the heat moving or it starts to bubble
loggyboy
posted on 11/10/10 at 09:32 PM Reply With Quote
Depends on the value of your eyesight!
Also I dont think perspex is MSA compliant (if that makes a difference for your use)
http://www.plastics4performance.com/Lexan--Makrolon--Perspex-race-and-rally-windows-and-window-kits/VOLKSWAGEN--Lexan--Makrolon-polycarbonate-windows/ SCIROCCO/WINDOW-KITS/c-1-288-524-540-641/
RazMan
posted on 11/10/10 at 09:48 PM Reply With Quote
As already advised, please avoid Perspex as it is very brittle in cold weather and shatters on impact - sometimes with just the flexing caused by trackdays
Polycarbonate is fairly pliable but I wouldn't attempt a compound curve without some serious heated former, large oven and a lot of skill.
Raz
tcr
posted on 11/10/10 at 10:33 PM Reply With Quote
cheers guys
will fixed plastic windows still pass an mot with sliders fitted ?
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
posted on 11/10/10 at 10:40 PM Reply With Quote
before you start, have a look for off the shelf kits. these are available for 205s etc although the Scirocco is maybe not so widely used.
tcr
posted on 11/10/10 at 11:04 PM Reply With Quote
looked at the link from loggy boy but they over £300
MK MIDI ZX10R
torquetune.co.uk
nrpexhausts.co.uk
phelpsa
posted on 11/10/10 at 11:18 PM Reply With Quote
I made the ones in my 205 out of 4mm polycarb (minimum for MSA) and the cost about £45. An hour or two with the jigsaw and jobs a goodun!
