dilley
posted on 26/10/10 at 11:16 AM |
busa fuel pump
Does anyone have the dimensions of an in tank pump? depth/hole diameter required?
Rustybin
posted on 28/10/10 at 12:38 PM |
I can measure up a pump (which is for sale!) at the weekend if you can wait until then?
Incidentally this is for a phase II pump with in built regulation. The Phase I are a different pattern I gather.
dilley
posted on 29/10/10 at 05:48 PM |
Yes please! can you u2u me a price?
Rustybin
posted on 2/11/10 at 05:49 PM |
Sorry for the delay. Work has been manic for the last few days.
Notes on dimensions below. I have sent a U2U if you are interested in purchase.
The hole in the tank would need to be approx 70mm diameter. The PCD of the mounting holes is approx 85mm with the flange approx 110mm wide overall. If
you need it exact I would suggest buy the gasket and work the dims from that.
With the fuel level gauge attached you need a minimum depth of 230mm within the tank. If you don't need a fuel gauge this comes down to 140mm.
You will also need about 55mm clearance on the outside of the tank as the pump is mounted half in and half out of the tank.
Cheers.
[Edited on 2/11/10 by Rustybin]
