Author: Subject: Electronic gauges, opinions?
TheDodge
posted on 26/10/10 at 08:36 PM Reply With Quote
Hi All,
Have been through the selection of smiths gauges my dad had put aside for the build many years ago. I realise that the rev counter is probably not compatible as i think the aldon dizzy has a magnetronic or optronic kit in it (will have to check it) the water temp is capillery and the end is knackered and the oil pressure requires a fluid line to it.
I really want to get away from this type and have electronic senders so i can run all the cables to a big multiplug under the dash for easy removal.
I don't however want all in one units or space age single dials as the car is going to have a 60's club racer feel.
As its only for sprints/hillclimbs i'll need a rev counter, oil pressure, and water temp gauges. Plus a big idiot lamp for low oil pressure.
Can anyone recommend any gauges that would fit the bill?
Can put the oil pressure sender in an existing mount point on the block?
Will i have to have two seperate senders for the oil pressure gauge and the oil pressure warning light?
Is the water temp sender better placed in the top or bottom rad hose? or tapped into the stat housing?
The engine is a crossflow.
austin man
posted on 26/10/10 at 08:43 PM Reply With Quote
you can still get smiths electronic gauges to keep the 60's look
I believe Europa have several types as do Burtons etc
marcjagman
posted on 26/10/10 at 08:46 PM Reply With Quote
Tim gauges look a bit retro, and a keen price.
big-vee-twin
posted on 26/10/10 at 08:53 PM Reply With Quote
Speedy Cables these are what I'm going to buy link
http://www.triangleltd.com
posted on 26/10/10 at 08:57 PM Reply With Quote
crossflow has sender in the head, same side as exhaust, just below the thermostat.
trick is to find a compatible sender unit.
irvined
posted on 26/10/10 at 09:24 PM Reply With Quote
Smiths do reasonably priced electronic guages, you can get retro looking facias. The price is good, although i've had a few failures over the years.
http://irvined.blogspot.com
Macbeast
posted on 27/10/10 at 06:46 AM Reply With Quote
Bought my temp, oil and petrol gauges from Europa. Not too expensive.
posted on 27/10/10 at 07:12 AM Reply With Quote
Have a look at the "RMD" range of instruments at Rally Design. These are made by Caerbont who make gauges for other re-sellers as well and are very well priced.
mcerd1
posted on 27/10/10 at 07:29 AM Reply With Quote
^^ Caerbont Automotive Instruments (CAI)
these days they make Smiths, Green Gauges & Eclipse International and I beleve they make the Revotec ones and quite a few others....
so any of them should be as good as an other it just comes down to price and the looks
http://www.caigauge.com/index.html
(I think speedy cables are something to do with them too)
[Edited on 27/10/2010 by mcerd1]
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 27/10/10 at 10:08 AM Reply With Quote
They are the same company, next door to each other and share the telephone!
I used them for Classic Smiths dials for my Cobra and a custom handbrake cable and would recommend them to anyone, although for cables you have to know EXACTLY what you need or the bloke will relish bamboozling you.
The Smiths dials can be specced any way you want.
RichN
posted on 27/10/10 at 10:53 AM Reply With Quote
I had mine from ETB Instruments, they do all sorts of colours and bezels. They also have a number of sender options. I found them very helpful on the phone and advising me what to use. They also re-calibrated my Tacho f.o.c. when I spec'd it wrong.
TheDodge
posted on 28/10/10 at 06:24 PM Reply With Quote
Thanks for all the great suggestions. Had a good think about price vs apperance and in the end i've gone for the TIM 52mm electronic water temp and electronic oil pressure. can't complain at £30 and £25 respectively with all senders included. I also like the black bezel, simple white numbering and white needle as its quite low key.
Just looking out for a 80mm tach with similar lettering and white needle, got a few on watch from the bay.
Some toggle switches and lamps are next on the list
