Author: Subject: Repairing Plastic Rad...
posted on 28/10/10 at 01:31 PM Reply With Quote
Got my Polo rad today... only problem is that the small bleed pipe on the plastic housing was broken off and lying in the packaging!
I've contacted the seller (ebay sale) to see what we can do, but not heard back yet.
One of the solutions I offered was to keep it for a (decent) partial refund and I would repair it myself.
Thing is... how best would you do it? Use an epoxy resin to put the pipe back on, or leave it off and get a small blanking plate to bond over the hole (I have a bleed at the back of the engine - tank to head inlet).
Not a great pic...
[img][/img]
It's Evolution Baby!
tomgregory2000
posted on 28/10/10 at 01:34 PM Reply With Quote
Take the money and wack a self tapper in it and block the hole
big-vee-twin
posted on 28/10/10 at 01:35 PM Reply With Quote
What about using Liquid metal, supposed to be ok upto 600 degrees.
http://www.triangleltd.com
twybrow
posted on 28/10/10 at 01:38 PM Reply With Quote
I used plastic cement (the stuff used to put together plastic hot water pipes etc). I used a small self tapper covered in glue, and it has never leaked a drop!
posted on 28/10/10 at 01:47 PM Reply With Quote
Cheers guys... the chap has since got back to me and offered me a tenner refund (I only paid £30 for it - including delivery).
Now I know that it's 'do-able' I'll go for that option... £20's not bad for a slightly-faulty but new Nissens rad I suppose!
TimC
posted on 28/10/10 at 01:58 PM Reply With Quote
Fo sho - I always regretted not blanking the hole on my MNR - its a pita to get a decent smooth run under a 7 nosecone for a start....
CNHSS1
posted on 28/10/10 at 02:36 PM Reply With Quote
tap hole and add a screw in barbed pipe fitting? summat from demon Tweeks for fuel system, 1/4" or similar or a fitting from compressor supplier
v8kid
posted on 28/10/10 at 02:52 PM Reply With Quote
The plastic taps nicely and you can insert a bolt for bleeding. Did it with mine and it works a treat
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
posted on 28/10/10 at 03:00 PM Reply With Quote
Thanks people!
Will have a look at it in the morning and see if I have enough 'meat' to tap it (its broken right at the base of the bleed pipe.
Breaker
posted on 28/10/10 at 03:41 PM Reply With Quote
Yes, Nissens are good quality. Which seller is it on eBay or linky ?
posted on 28/10/10 at 04:04 PM Reply With Quote
I'm afraid it was the last one he had Breaker.
mangogrooveworkshop
posted on 28/10/10 at 05:21 PM Reply With Quote
Scott
Take a m6 and tap the hole out.
Apply some PU adhesive and screw the m6 bolt and washer in.
put another washer inside and a nut.... job done.
My old rad was like that and we never had a problem with it......
[Edited on 28-10-10 by mangogrooveworkshop]
posted on 28/10/10 at 05:31 PM Reply With Quote
Cheers Mango!
posted on 28/10/10 at 05:44 PM Reply With Quote
if you gete stuck, there is thisd
no broken bits at all.
posted on 28/10/10 at 05:51 PM Reply With Quote
Cheers, but too mahoosive!
irvined
posted on 28/10/10 at 06:36 PM Reply With Quote
If you don't need the fitting, then screw in a self tapper and some epoxy - mine broke on the way to morocco, and its held ever since.
If you do need it as said you can get a hose barb that should do the job.
http://irvined.blogspot.com
