Author: Subject: Rally Design Hubs on Original Cortina Uprights
mcg
posted on 5/11/10 at 08:06 AM Reply With Quote
Just assembled my nice new alloy hubs onto the original cortina (Mk4/5) steel uprights, and the nut fastens on a good 5mm further down the shaft than I would have expected, meaning that the retaining 'crown' and split pin are rendered in effective as the crown can just rattle around. The plan is to use a few washers to fill the space, but just wanted to check that I am not missing anything obvious / important?!?
Matt
daviep
posted on 5/11/10 at 09:31 AM Reply With Quote
There should be a thick washer between the nut and the bearing is that fitted?
Davie
mcg
posted on 5/11/10 at 01:52 PM Reply With Quote
Yer there is - it has a little tab which lines up with the notch on the shaft...
Davie
markt0121
posted on 5/11/10 at 04:46 PM Reply With Quote
Does it need a bearing seat fitted to the alloy hubs? Maybe it's a stupid question. I just checked in the haynes cortina workshop manual, but the diagram doesn't show a bearing seat fitted to the hub. I'd be surprised if a bearing seat wasn't needed in an alloy hub.
mcg
posted on 5/11/10 at 11:48 PM Reply With Quote
Yer has a bearing seat made of stainless steel i think. Had to do the old hot cold trick to get em into the ally hubs
