thepest
| posted on 5/11/10 at 02:11 PM |
Zetec SE injectors
Anyone know what the size of these injectors are? Engine is from a 1996 ford fiesta and is 1250 cc?
Also are they high or low impedance injectors?
Cheers & thanks
Madinventions
| posted on 5/11/10 at 03:23 PM |
I don't know the flow rates unfortunately, but mine measure about 11 ohms each, so they're low impedance.
Good little engines by the way!
Ed.
View my band website:
http://www.shadowlight.org.uk
will121
| posted on 5/11/10 at 05:26 PM |
are they the side fed ones, if so what colour? the brown 97MF-BA 1.4 fiesta ment to have a flow rate of 135cc/min so 1.25 would say this or less, also
15.7 ohm which i think is high impedance
[Edited on 5/11/10 by will121]
big_wasa
| posted on 5/11/10 at 05:56 PM |
At 11 ohms they are high (z) you would be measuring 2~4 ohms for low Z
beaver34
| posted on 5/11/10 at 07:22 PM |
anyone know what other injectors will fit in place of the stock ones
will121
| posted on 5/11/10 at 08:51 PM |
are they side fed ones like this?
if so and can measure them i will check they are the same as 1600Si ones if so these should fit as replacements
RS1800 XR2i
Part number - Bosch 0280155503
Flow rate - c190cc/min at 3bar
Mondeo 2litre
Part number - Ford 948F-B2B (beige)
Flow rate - c225cc/min at 3bar
RS2000
Part number - Bosch 0280155504
Flow rate - c250cc/min at 3bar
1600 Zetec
Part number - Ford 948F-AB / 948F-A2A (black) / 567 31 2471
Flow rate - c150cc/min at 3bar
beaver34
| posted on 6/11/10 at 08:26 AM |
no not side feed, ill get a pic of them up
thepest
| posted on 6/11/10 at 10:24 AM |
They are not side fed, I'll get a photo sorted out & posted.
Thanks for the info everyone
Does anyone have reference to a haynes ford fiesta manual 1995-2002? I'm guessing that such info could be found in there... am I right?
beaver34
| posted on 6/11/10 at 11:11 AM |
thanks saves me getting a pic, i need some injectors that will flow enough for 300bhp
