perksy
posted on 14/11/10 at 09:33 PM |
Vauxhall 1600 Ecotec - Anybody Fitted One ?
Just wondered if anybody on here has fitted a Vauxhall 1600 Ecotec engine into their 7 ?
If you have i need to pick your brains
Have one coming into the garage for a few jobs and it'll then be going in a 7
zilspeed
| posted on 14/11/10 at 10:00 PM |
Haven't done it myself, but I've seen it getting used to wonderfull effect in the Westfield of Garry Dickson.
This car
Ticks over in the paddock like a bog standard Astra, revs like a bike engine.
Magnificent choice of engine.
DorsetStrider
| posted on 15/11/10 at 12:40 AM |
I'm currently fitting a 2 ltr ecotec... but remember that mine is not a seven chassis and I'm still at an early stage of construction so
not sure how much help I'll be.
Who the f**K tightened this up!
mediabloke
| posted on 15/11/10 at 01:39 AM |
Ran a 1.6l Ecotec Indy for a couple of years. Rebuilt and megajolt fitted. Happy to pass on anything useful.
Think I have the Haynes manual hereabouts if you need it!
loggyboy
| posted on 15/11/10 at 01:16 PM |
http://www.sbdev.co.uk/History_files/History_InstantExpert.htm
alistairolsen
| posted on 15/11/10 at 03:45 PM |
I have one I fitted in a nova depending on what the questions are?
My Build Thread
jacko
| posted on 15/11/10 at 08:42 PM |
Sonic on here had one in a MK indy
perksy
| posted on 15/11/10 at 10:09 PM |
Thanks Lads
ok a few questions
The engine will be attached to a Type 9 Ford Gearbox and will be running on 40 dcoe's (fitted to a Westfield)
1, What sump did you use ? Did you use a shallow one, Baffled ? or Standard ?
2, What Clutch Assembly did you use ? and What Release arm & Bearing ?
3, When fitting a new timing belt kit did you go standard (plastic pulleys) or steel ones ?
ANY Help Much Appreciated including details of suppliers etc
Perksy
mediabloke
| posted on 15/11/10 at 11:48 PM |
I've got a Camskill head gasket, a set of valve stem seals, manifold and oil-pump gaskets if you need them. Pics in my photo archive if
you're interested. I haven't got round to putting them on the For Sale page yet...
Oh - and if you've got a spare couple of hours, you don't necessarily have to replace noisy lifters: it's worth stripping down,
cleaning the lifters if you find the cam a bit tappetty. Messy as hell but v. rewarding when you hear how much quieter it runs.
Answers below in italics
quote: Originally posted by perksy
Thanks Lads
ok a few questions
Mine appeared to have been shallowed with some ally plate, with a shortened pickup but had the std flat Ecotec baffle
Std flat flywheel, so it was a std. Ecotec clutch. A guy on MigWeb makes lightened flywheels to order for any of the VX engines. Think he was
asking about £120 for them. Cheaper than having a go yourself and having to source a new set of 'nads...
I fitted a steel tensioner pulley, as the stock ones appear to have a rep. for shedding. Both the original and replacement guide pulleys were
plastic. I don't recall seeing metal ones.
I know that they're not local to yourself but these guys were brilliant when I was looking for gasket sets, stem seals & rings.
I'd recommend them to anyone:
Lockstitch
Perksy
Francis
Rich J
| posted on 16/11/10 at 07:41 PM |
I'm fitting a c16 xe to my Striker over the winter and have had a sump made by Bill Falconer up in Scotland
Asked me for a few critical dimensions and I sent him a couple of photos fo the current crossflow set up and he produced this in no time.
Web site here
http://billfalconer.webs.com/
Lovely guy to talk to on the phone - very helpful and all the time in the world
Rich
[Edited on 18/11/10 by Rich J]
perksy
| posted on 17/11/10 at 09:33 PM |
Thanks for the info so far Lads, Very Helpful
So Just to clarify then, the Standard Ecotec clutch plate will fit the input shaft on the Ford type 9 Gearbox ?
Hadn't heard of Bill Falconer but just had a look on his website and there's some useful info there
Interesting that his clubman engine on the dyno uses standard plastic idler pulleys but a steel tensioner pulley
So that must work ok
Any more info appreciated, especially any more info on the clutch plate and the release bearing
SBD recommend their release bearing which is around £40 iirc
Perksy
mediabloke
| posted on 18/11/10 at 11:54 PM |
I'd just check the clutch type with SBD. They will doubtless sell a kit, and so should know the components. If I'd have needed one for
the Indy, I wouldn't have wanted to risk it.
Try Chris Astley Motorsport, too. Chris was also a really helpful source of info when I was looking for tuning parts for my Indy (used to use redtops
& Ecotecs for their rally cars, iirc.)
martyn_16v
| posted on 19/11/10 at 11:12 AM |
On a C20XE I use a Ford clutch plate, I think off the top of my head it's a sierra diesel one. That's what Yukspeed sent me, I just
assumed the splines were different between the VX and Ford gearboxes, but never actually checked to be fair.
Found the part no, C1175AF from QH. That is for a C20XE though, don't know if it's suitable for a 1600.
[Edited on 19/11/10 by martyn_16v]
perksy
| posted on 21/11/10 at 03:55 PM |
Thanks Everybody for the help
Have quite abit of info' on this conversion now including info' from WSCC users
So if anybody needs any info on this conversion in the future just let me know and i'll email everything thats been sent to me
Perksy
