MsD
posted on 2/12/10 at 04:38 PM |
Running gear help....
.. Just at the stage of fitting the front uprights- but im not quite sure on the orientation of them-
Is it this way(1)-
or this way(2)-
Sorry about the different angle of picture; hopefully you get the idea!
Also can any one identify the uprights? And also the brake calipers (believed to be mk2 RS2000??)
One final thing- To keep all of you who are snow bound occupied; Does anybody know a company/ person that has all the braking components for an Atlas
axle? Im running out of ideas on who to go to!
Heres what ive got in terms of brakes-
Cheers LocostBuilders
Mark.
Daddylonglegs
posted on 2/12/10 at 04:41 PM |
# 2 old bean
Pretty sure they're Cortina uprights.
[Edited on 2/12/10 by Daddylonglegs]
Kriss
posted on 2/12/10 at 04:46 PM |
second pick witht he steering tie rod ends facing forward and low
MsD
posted on 2/12/10 at 04:47 PM |
Smashing thanks... Ill go and get them fitted! Youll have to excuse my inability sometimes Haha!
If anyone knows the other answers itll be greatly appreciated
irvined
posted on 2/12/10 at 04:49 PM |
Definitely cortina uprights.
http://irvined.blogspot.com
T66
Rallydesign stock Atlas axle bits
UncleFista
posted on 2/12/10 at 05:01 PM |
Standard m16 calipers (as fitted to cortinas, capris and some escorts) as far as I can tell
Tony Bond / UncleFista
Daddylonglegs
posted on 2/12/10 at 05:05 PM |
That'll be you sorted then?
blakep82
posted on 2/12/10 at 05:19 PM |
yep, cortina uprights, so as per #2
BUT WAIT! the steering track rod enters the hole in the upright from underneath i'm sure? ( i don't know, i don't have them)
the hole is tapered, and the taper in the hole should fit the same way as the track rod
[Edited on 2/12/10 by blakep82]
________________________
Daddylonglegs
posted on 2/12/10 at 05:23 PM |
Good spot that man! Absolutely right, it should enter from underneath.
I should have spotted that one, it's been a long day
austin man
posted on 2/12/10 at 07:54 PM |
cant you modify sierra backplates to fit the axle if so you can fit larger drums
MsD
posted on 2/12/10 at 08:41 PM |
With regards to the steering rack ends- I just put them in the holes quickly without checking; just to take the picture! And yeah, they are tapered-
so they do need to be the otherway around... Good spot anyway!
Ill have another search for Atlas Axle bits and pieces- but obviously as its such an old part; they are pretty hard to come by! I know 'Fostech
(??) engineering specialise in Atlas bits and pieces, and also do a conversion for sierra rear discs! Ill pop them an email and see what they say.
Cheers guys- Youve done me a huge favour
blakep82
posted on 2/12/10 at 09:04 PM |
when i asked fostek about full floating modded atlas axles, he was, er, not very helpful. kind of like, i should know all this if i'm doing it,
and he shouldn't need to give me any advice. needless to say he didn't get my business either
