Author: Subject: Wiring LED toggle switches?
leemarkadams
posted on 22/12/10 at 11:15 PM Reply With Quote
Hello all, finished my dash (almost) and have a question regarding the LED toggle switches I have. How do you wire them up to light up when switched on? They have 3 connections (Earth/Acc/+ve), now I can get the switches to work using the Acc and +ve terminals, but no matter what I do I can not get the LEDs to light when on. I can get them to come on all the time, but not switched......
Lee
franky
posted on 22/12/10 at 11:30 PM Reply With Quote
Are they switching relays?
blakep82
posted on 23/12/10 at 12:27 AM Reply With Quote
i thought all you had to do was earth the earth connection? +ve is obviously 12v live, acc goes to whatever's being switched, and i thought the earth completes the led connection (+ve, switch, earth)?
________________________
speedyxjs
posted on 23/12/10 at 07:46 AM Reply With Quote
Thats what i have done with mine and it works.
leemarkadams
posted on 23/12/10 at 07:51 AM Reply With Quote
Thanks, I thought that is what I had done, but I will try again later. Not sure of they are switching relays, as the switches are for the fan/fog light/fuel pump.
I will get it sorted and once more thanks for all the help.
Lee
franky
Same here, if he was using relays I had a drawing, well more of a etch-a-sketch!
franky
posted on 23/12/10 at 07:52 AM Reply With Quote
if they are switching fuel pump/fan/fog they *should* go through a relay.
Grimsdale
posted on 23/12/10 at 08:38 AM Reply With Quote
Lee,
if you're switching the earth from your circuit, then the LEDs will not light, as when the switch is on, there's no potential difference between the wire coming in and eart, as they are directly connected.
You need to switch the positive feed from the battery before your circuit.
leemarkadams
posted on 23/12/10 at 11:26 AM Reply With Quote
Thanks once more for all the help, just checked and they switch the negative side......oh well it will have to wait!
Lee
