Author: Subject: alluminium petrol tank
nick-york
posted on 26/12/10 at 09:47 AM Reply With Quote
planning on making an alluminium petrol tank but can t find any reference anywhere as to how thick the alluminium needs to be . Is there a reccomended thickness or a minnimum requirement for the iva ?
chunky2772
posted on 26/12/10 at 09:52 AM Reply With Quote
Ive used 3mm ally for mine as i think anythink thinner just wouldent be suitable for a fuel tank.
big_wasa
posted on 26/12/10 at 10:15 AM Reply With Quote
How thin can you weld with out blowing holes and distorting it ?
Moorron
posted on 26/12/10 at 10:25 AM Reply With Quote
1.6 for mine.
StrikerChris
posted on 26/12/10 at 10:29 AM Reply With Quote
2mm for mine!
mangogrooveworkshop
posted on 26/12/10 at 11:18 AM Reply With Quote
If you swage the thin metal it will be stiffer, we are at 1.6
Its not the thinness or thickness but the way its put together, that makes it strong.
running a few ribs with the swager makes a difference.
RazMan
posted on 26/12/10 at 02:46 PM Reply With Quote
The same goes for internal baffles too
Raz
nick-york
posted on 26/12/10 at 03:24 PM Reply With Quote
Thanks everyone . some good advice.
gavinpurvis
posted on 26/12/10 at 04:58 PM Reply With Quote
does it make much difference to the weight? i have a green one that just needs fitting, not sure if it is worth the work though
irvined
posted on 27/12/10 at 02:47 AM Reply With Quote
Mine is 2mm, with the fliddly bits: sender mount, filler neck, being 3mm. I had to weld most of it myself with a tig, and it doable without too much distortion.
http://irvined.blogspot.com
:{THC}:YosamiteSam
posted on 28/12/10 at 12:18 PM Reply With Quote
2mm for my old one - remember when you need gaskets to seal etc - it needs to be flat - thin can make it harder as it may bend a bit
weight wont really be an issue unless your racing
