Author: Subject: Immobiliser certificate for iva
Davegtst
posted on 26/12/10 at 01:41 PM Reply With Quote
I've got a transponder immobiliser i'm going to fit to my indy to satisfy mr IVA man. It's a cat 2 immobiliser but it didn't come with any certificate. Do i need one that shows it was fitted by an approved installer for the IVA?
speedyxjs
posted on 26/12/10 at 02:22 PM Reply With Quote
I think that section was removed from the IVA manual so you should be ok
FrankP
posted on 26/12/10 at 03:24 PM Reply With Quote
I didnt need one - I thik its been removed.
ou will still have an alternative security devoce as well as the ignioton key.
If you leep the sierra steering column some people use the steering lock.
Some peopl put aswitch or key somewhere to act as a master switch.
Frank
Chaddy
posted on 26/12/10 at 03:36 PM Reply With Quote
Thats my understanding after reading the newest version of teh IVA manual (not all of it!!!)
stevegough
posted on 26/12/10 at 04:26 PM Reply With Quote
Originally posted by FrankP
Frank
Careful if the master switch is the battery isolation type - you need to be able to use the hazard lights even with it 'off'.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
irvined
posted on 27/12/10 at 02:38 AM Reply With Quote
You do not need a certificate for IVA, it was removed a couple of revisions ago. As has been said: you do still need two methods of immobilizer though, - ie ignition key and immobilizer.
http://irvined.blogspot.com
big_wasa
posted on 27/12/10 at 10:33 AM Reply With Quote
Ignition key and steering lock should be fine.
Davegtst
posted on 27/12/10 at 02:13 PM Reply With Quote
Thanks everyone. I'm not using the sierra steeing lock and key. I'll be using an on/off ignition key switch and this transponder immobilier so i should be ok.
