jacko
| posted on 29/12/10 at 11:18 AM |
Battery chargers
Hi all as part of my xmass presents i was given a Auto-xs charger [ lidl or aldi ] has anyone used this make type are they any good ? and do you need
to remove a lead of the car when using them
Jacko
MakeEverything
| posted on 29/12/10 at 11:39 AM |
RTFM?
Kindest Regards,
Richard.
blakep82
| posted on 29/12/10 at 12:06 PM |
quote: Originally posted by MakeEverything
RTFM?
WDTM?
________________________
MakeEverything
| posted on 29/12/10 at 12:08 PM |
RTFM?
WDTM?
Read the Flippin' Manual.
Tthe precautions and procedures will (Should) be listed here.
Kindest Regards,
Richard.
graememk
| posted on 29/12/10 at 12:09 PM |
Read The F? Manual
blakep82
| posted on 29/12/10 at 12:13 PM |
ah right, i get you
skippad
RTFM?
What does RTFM mean?
I bought one of those chargers from Aldi, been used for over year...
i think it works ok, having said that i've got a problem with charging my Powervamp battery.
It is showing its fully charged, but it wont start engine (my meter shows its only got 6v!)
The battery is only 6 months old, so dont know whether its the charger goosed or cold temps have killed
the battery!
Anybody got any ideas?
MakeEverything
| posted on 29/12/10 at 12:14 PM |
RTFM?
the battery!
Sounds like a nackered / frozen battery to me?
Kindest Regards,
Richard.
PSpirine
| posted on 29/12/10 at 12:35 PM |
Some chargers work for both 12v and 6v batteries. If yours happens to be this one and your battery is completely flat, it may only charge it up to 6v
and think it's fully charged. What I'd suggest is if you can get a car running and use jump leads to charge it to 10v or thereabouts from
the alternator, then the charger should take it up to 12v.
I've managed to bring back batteries that were completely - 0v - flat, and they've worked fine since - all it takes is a bit of charge
cycling, even with cheapo simple chargers!
skippad
| posted on 29/12/10 at 12:56 PM |
I think you could be right
I kept it on trickle charge since taking car off the road end of October.
I had to move car in garage couple of weeks and took it off charge (it was showing fully charged)
Connect it up couple of days ago, showing fully charged at 6v.
I'll try what you suggested
Skipp
whitestu
| posted on 29/12/10 at 01:07 PM |
I have the Lidl charger and the only flaw I've found is that it needs to detect a voltage to start charging so if the battery is totally flat it
won't do anything. It's easy to overcome as long as you have another 12v battery you can connect to start it charging.
Stu
MakeEverything
| posted on 29/12/10 at 01:08 PM |
Good point.
Kindest Regards,
Richard.
Bluemoon
| posted on 29/12/10 at 03:50 PM |
Yep it's a good one, they are a copy of the more expensive CTec chargers (i.e three stage charging) . I have been using one for over 2 years on
our caravan leisure battery, been really good. It also has a high voltage charging setting that is good to use once in a while to stop sulphate
forming (this is the 14.7V setting I think, the "frost" setting).
Dan
SPYDER
| posted on 29/12/10 at 07:04 PM |
Another vote for the AutoXS.
No problems with mine.
steve8274
| posted on 29/12/10 at 07:41 PM |
i could do with a charger?
are these a decent price?
was it aldi or lidl and how long ago where they on sale?
thanks
steve
jacko
| posted on 30/12/10 at 12:28 PM |
thanks
steve
Steve i think it was £9.99 or £12.99 and that was just before xmas
| posted on 30/12/10 at 12:57 PM |
I have one and its been very good keeping all my batterys charged.
Settings for 6v or 12v and frost charge. Once the battery is full it goes into a trickle charge so no problem with overcharging.
westy turbo
| posted on 31/12/10 at 12:14 AM |
thats what i bought last month and is great!
OPTIMATE 4 12V MOTORCYCLE BATTERY CHARGER on eBay (end time 02-Jan-11 08:38:00 GMT)
steve8274
| posted on 2/1/11 at 06:44 PM |
thanks
steve
hi do you know if it was aldi or lidl? been to my local ones but none in, dont mind travelling as long as know which stores to go to
thanks
steve
