Author: Subject: Guide to making metal tube (not pipe) bender at home
MikeR
posted on 1/1/11 at 04:50 PM Reply With Quote
Guys,
This comes up once a while and whilst looking up making a sheet metal bending brake thingy i came across this. He reconmends using a lathe to make a couple of bits, but gives details and suggestions on how the same parts can be made in a pillar drill.
http://www.metalwebnews.com/manuals/pipebend-machine.pdf
Love to hear somones results making this.
[Edited on 1/1/11 by MikeR]
Bluemoon
posted on 1/1/11 at 05:27 PM Reply With Quote
Looks like fun, I think the only issue will be if you want to bend thick wall tube, for say wishbones (not sure how thick thick is though he may say) you might need better formers, i.e. solid steel..
Dan
MakeEverything
posted on 1/1/11 at 05:33 PM Reply With Quote
Im going to make a manual version using the hydraulic dies and rollers. Itll look exactly the same when its finished, but with proper formers.
Kindest Regards,
Richard.
Humbug
posted on 1/1/11 at 05:51 PM Reply With Quote
Originally posted by MikeR
Guys,
Why do you say it is Guide to making metal tube (not pipe) bender? The guide itself says it is for a pipe bending machine...
Also, I think I could help if anyone needs a supply for quenching the case hardened steel (Page 8)
MikeR
posted on 1/1/11 at 08:05 PM Reply With Quote
I appreciate that, but wanted to differentiate it on the front page from the pipe benders & as it did thin wall + you make the formers yourself it can do tube.
interestedparty
posted on 1/1/11 at 10:36 PM Reply With Quote
Basically the author is going aagainst convention by describing it as a pipe bending machine. Pipe (usually) means material for carrying fluids, and is usually measured buy its inside diameter, whereas tube is measured by its outside diameter and is structural
gazza285
posted on 1/1/11 at 11:10 PM Reply With Quote
Those instructions are no good for you lot, it shows pictures of proper welding, not MIG
907
posted on 2/1/11 at 07:41 AM Reply With Quote
Inside rad cutting tool
Mmmm, I have doubts about using a pillar drill to make the formers
but for anyone contemplating making steel formers on a lathe then
the pic below may help.
Turning the allen key moves the cutting tip in an arc. It works well.
HTH
Paul G
lathe tool
lathe tool
John Bonnett
posted on 2/1/11 at 11:23 AM Reply With Quote
Paul a really good idea. Can you show a detail pic showing how the tool is gripped in the bolt.
Many thanks
John
907
posted on 2/1/11 at 03:03 PM Reply With Quote
An M8 grub screw down the centre of the M12 allen screw does the trick John.
Paul G
lathe tool exploded view
John Bonnett
posted on 2/1/11 at 06:35 PM Reply With Quote
All is now clear Paul, thank you,
John
ruudbeckers
posted on 2/1/11 at 07:17 PM Reply With Quote
For a tube/pipe bender also have a look here:
Instructions
Drawings
It is a similar bender to the JD2 model III bender or the Pro-Tools model 105 bender.
I believe you can also use the forms of these benders but you can also make your own forms. You could use a ball turning attachment on a lathe to make one of these, for example this one: Ball turning attachment
[Edited on 2/1/11 by ruudbeckers]
John Bonnett
posted on 3/1/11 at 01:03 PM Reply With Quote
A really good and useful post Ruud, thank you
John
