Author: Subject: Ali Panels, how did they do this?
Irony
posted on 4/1/11 at 12:11 PM Reply With Quote
Luego posted up on their facebook page this image of a car they have refurbished. I wanted to know what they did to the Ali to get it so polished. I wanted to do this myself. I don't want to use buffing wheels or Salvo Autosol. I thought they must have wiped on some sort of etching fluid.
I posted on the Luego page but no reply (again).
John Bonnett
posted on 4/1/11 at 12:16 PM Reply With Quote
It is difficult to see from the picture exactly how polished the aluminium is but you can achieve a very good finish just using Scotchbrite which is available in various grades.
Mal
posted on 4/1/11 at 12:23 PM Reply With Quote
Or by using aluminium with a protective plastic film and not removing it until the job is finished.
richard thomas
posted on 4/1/11 at 12:29 PM Reply With Quote
Looks like it's had a scotchbrite wheel over it?
blakep82
posted on 4/1/11 at 12:31 PM Reply With Quote
you want to know how they did it so you can avoid making the same mistake?
looks to me like someones had a go at sanding it, looks un uniform, actually looks dented in the photo. doesn't look polished to me, but you can't really tell much from a photo without actually seeing it really
________________________
posted on 4/1/11 at 12:32 PM Reply With Quote
^^^That's what I was thinking^^^
It's Evolution Baby!
speedyxjs
posted on 4/1/11 at 12:35 PM Reply With Quote
I think it'll look quite good when finished and covered in carpet
Irony
posted on 4/1/11 at 12:40 PM Reply With Quote
I have my ali panels off and I wanted something I can just rub on and create some sort of presentable finish. I really can't be bothered with the whole wheel in a drill thing. Although I do have all that kit.
I was after a quick fix I guess. Suggestions anyone??
RazMan
posted on 4/1/11 at 12:49 PM Reply With Quote
Scotchbrite pads rubbed in one direction can give you an attractive brushed finish. Looking at the pic, I reckon they just stuck a Scotchbrite wheel on it and went crazy - I can't think why they would want to do that to their new panels.
Raz
daviep
posted on 4/1/11 at 12:50 PM Reply With Quote
The panels look like they've been buffed with a scotch brite wheel on an angle grinder, you'd get a much better finish with a polishing mop.
Davie
loggyboy
posted on 4/1/11 at 12:54 PM Reply With Quote
Similar (and better IMO)
http://forums.bit-tech.net/showthread.php?t=114028
franky
posted on 4/1/11 at 01:26 PM Reply With Quote
once you do the above it won't take much for them to show signs of corrosion.
myke pocock
posted on 4/1/11 at 01:43 PM Reply With Quote
Or a fine flap wheel in an angry grinder. Dont like it meself but everyone to their own.
mcerd1
posted on 5/1/11 at 06:13 PM Reply With Quote
not done it on sheet alloy yet but these worked well on some of the bits I've made: mop linky (assuming you want a satin finish not a polished one...)
[Edited on 5/1/2011 by mcerd1]
Confused but excited.
posted on 5/1/11 at 06:50 PM Reply With Quote
A polished finish will last longer. An etched or brushed finish will corrode like nobody's business if left unprotected from the air.
Ask me how I know.
mcerd1
posted on 5/1/11 at 06:57 PM Reply With Quote
Ask me how I know.
thats why I had my bits clear anodised afterwards (not very locost mind you )
Irony
posted on 6/1/11 at 09:48 AM Reply With Quote
It seems there is no easy solution to this aluminium sheet thing. I could try clear powder coating a sheet but I don't know how I am going to bake it. I shall eventually post up my results.
I might try using the mop or perhaps scotchbrite.
posted on 6/1/11 at 03:24 PM Reply With Quote
Ask me how I know.
I'm with you on that one, by far the best method and comes in pretty colours if required.
loggyboy
posted on 6/1/11 at 03:31 PM Reply With Quote
Heat gun:
a sheet would easily soak up the heat and not take 'too' long.
sm1ggles
posted on 6/1/11 at 08:58 PM Reply With Quote
ali bits
i use brasso to clean my ali panels its hard work but worth it
mid-buggy
posted on 6/1/11 at 09:32 PM Reply With Quote
Elbow grease and all in the following link:
http://www.i4detailing.co.uk/acatalog/Metal_Polish_Sealant.html
posted on 6/1/11 at 10:12 PM Reply With Quote
Ask me how I know.
Home anodising isn't tricky. But you'ld need a bloody big tank to do it in....
