AdrianH
posted on 14/1/11 at 07:00 PM |
Tadpole strip for rear arches, how to fasten?
Granted this may be a stupid question to many. The strip I have has 40mm tail and it looks as though I will have to cut triangles out of it to sit
correctly along the end of the rear arch.
My question is do you use double sided tape to stick it to the wing before you then bolt through to the bodywork?
have I bought strip with too much tail or is the notching out quite common for any-size?
Adrian
Why do I have to make the tools to finish the job? More time then money.
big_wasa
posted on 14/1/11 at 07:13 PM |
I notched mine and stuck it to the wing.
tomgregory2000
posted on 14/1/11 at 07:22 PM |
notched mine and then super glue
spdpug98
posted on 14/1/11 at 07:44 PM |
Notched trim and didn't stick it, just clamped between tub and arch
My Blog: http://spdpug98.wordpress.com/
steve m
posted on 14/1/11 at 08:08 PM |
ditto
martyn_16v
posted on 14/1/11 at 08:40 PM |
notched and superglued, which all peeled off the first time I took the arches off, now just stuffed back in place and clamped by the arch ![](/images//smilies/smile.gif)
big-vee-twin
posted on 14/1/11 at 09:07 PM |
Just clamped between the wing and rear panel, bolts pass through the trim
![](/galpreviews/wheel arch fixings.jpg) ![Rear arch fixings](/gallery/wheel arch fixings.jpg) Rear arch fixings
![](/galpreviews/first rear arch2.jpg) ![First of Rear Wheel Arches](/gallery/first rear arch2.jpg) First of Rear Wheel Arches
[Edited on 14/1/11 by big-vee-twin]
http://www.triangleltd.com
AdrianH
posted on 14/1/11 at 09:40 PM |
Thanks for the replies guys. Looks as though notching is quite normal although the pictures there seem to suggest that one is not. I will try to
stick to arch and notch as I go to make it easier to keep in place whilst I work.
Adrian
Steve Hignett
posted on 14/1/11 at 09:46 PM |
Notch it and don't be shy.
If you want to make it slightly easier for fitting and especially removal and refitting if it ever happens, then rivet the piping to the wing in a few
places...
[Edited on 14/1/11 by Steve Hignett]
RK
posted on 14/1/11 at 11:37 PM |
Another good trick i wish i'd used from mr H (the good one, not the other one)!
Bluemoon
posted on 14/1/11 at 11:44 PM |
notched and evostick impact adhesive on mine.. Used PVC P trim.
