Author: Subject: New Build
Markymark
posted on 18/1/11 at 10:36 PM Reply With Quote
New Build
Hi All
Been on the fringe of this site for a while, but now there is some progress I thought I'd put a post up
1: Chosen engine, Alfa V6
2: Chosen gearbox, Mazda RX8
3: Mock up of gearbbox adaptor
4: Adaptor plate made
5: Gearbox lined up
6: Just a cut out for the slave cylinder required
(See pics in arcive as they come out way too BIG when posted)
Must learn how to resize, but gripped by the techno fear
All connected by a Galaxy friction plate and Alfa pressure plate
All opinions welcomed (but not always heeded)
Regards Mark
steve m
posted on 18/1/11 at 10:46 PM Reply With Quote
All very nice, but that engine and gearbox will be looking very silly in your garage without a chassis, wheels, body clothing it
So whats it going to be ???
invisible ?
mookaloid
posted on 18/1/11 at 10:47 PM Reply With Quote
nice work - how do you work out how to do the adapter plate, how do you make sure length of input shaft is correct, clutch parts which gearbox to choose etc etc?
mark
i_froloshki
posted on 19/1/11 at 06:44 AM Reply With Quote
Hi there, would you tel me if it is a push type slave or pull type, because i have a lot of problems finding a pull type, there is only one wilwood that i found so far. Thanks
Yavor
designer
posted on 19/1/11 at 09:01 AM Reply With Quote
Resize your pictures with:
http://bluefive.pair.com/pixresizer.htm
Markymark
posted on 20/1/11 at 11:32 PM Reply With Quote
Thanks for your comments
In answer to your questions
Slave cylinder is standard RX8 push type, using alfa push type clutch cover
As to chassis/body engine and gearbox are off to Steve at Fisher Sports Cars to build me a chassis for it on Saturday, then modified Fury bodywork.
As to mookaloid's question it all started with the engine, had to be Alfa, had to be V6. Started looking at various 'boxes, BMW, Ford, Vauxhall etc. then I drove an RX8 and thought what a sweet box it had, checked out the ratios and they seem pretty good. Saw 1 cheap on e-bay and bought it.
Then came the fun part, started by just offering up box to engine for size, seemed a pretty good match up size wise, then drilled a hole in a piece of MDF the size of the spigot shaft, stood the box on its end and drew round it. Then offered that up to engine and marked holes.
Once cut out this was trial fitted and measured
Adaptor mock up
Adaptor mock up
It was only then I realised that I had forgotten the starter mounting, so started again
Once the mock up was made and a clutch plate found by looking in the National clutch catalogue and checking specs, I could work out how close I needed the box to be to the engine.
Clutch assy
Clutch assy
I used 16mm Alloy and got 6mm machined off the bell housing, so the clutch plate sits on the shaft in the right place. With counter sunk bolts into the engine side. All cut by hand
Adaptor plate on engine
With no spigot bearing ever being fitted to the Alfa V6, I have designed a bearing carrier that mount on the fly wheel and locates in the end of the crank.
To make sure it ran true I fixed a DTI to the flywheel face and measured the run out, with great difficulty through the hole int the bell housing.
The closest I could get is .3mm (I hope this is going to be ok! there is plenty of movement in the spigot shaft anyway). I then drilled and dowlled into the gearbox face to locate it.
These are the wheels I am going to use (100 build points to whoever identifies them) as they only cost £15 the set just need to get the centres machined out a bit!
Alloy wheel
Alloy wheel
Thanks for the link designer (I hope this works)
Mark
