<<  1    2  >>
Author: Subject: IVA retest issues - before / after.
stevegough
posted on 23/1/11 at 10:57 PM Reply With Quote
Ok, following this earlier post of mine: Fail list
I have now completed the fixes -and as posts are better with pics - here we go.....
Bias bar now lockwired:
VIN position was not to his liking:
Foglight - wrong lens - see also thread: foglight
Now much better:
Steering column extension bolts have no locking device: now nylocked:
Diff rear mount - only 2 bolts:
and after....
Rear camber adjuster locknuts hand tight - and better with 2 each side... Silly mistake - didn't tighten them up after setting the camber!
Here is one I have never come across - he reckoned with the Sierra front upright 'mushroom' converters only being held in with the 12mm pinch bolt (secured with a nyloc) there is a possibility of it coming out, so drill and fit a bolt as a secondary locking device. -Was easy enough - 8.8 grade M8 30mm bolt and nyloc inside.
Horn wire exposed and uninsulated:
Advised to change the wheelnuts:
The dished washers didn't tighten up - they were the wrong shape.
Fitted these instead...
Sharp edges: Wishbone bracket not covered sufficiently here...
Replaced with edge trim:
Not happy with no cover under wiper motor:
So this is the 'after'...
And a couple of other jobs I haven't photographed:
Exhaust clamp and stud sharp edges sorted, and the handbrake cable blob of weld had pulled off - fixed with electrical connector blocks as advised by a couple of other Locosters on here.
As always, comments are invited,
[Edited on 24/1/11 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
blakep82
posted on 23/1/11 at 11:09 PM Reply With Quote
i worry that you might need longer studs on those wheels, they normally like to see the stud sick out the end of the nut by a few threads dont they?
though it don't know how that works with the closed end type of nuts, but they don't look right to me i'm afraid
________________________
RichardK
posted on 23/1/11 at 11:10 PM Reply With Quote
Mostly looking good mate, the two things I would pick up on would be the wheel nuts, I think longer studs are required as they tend to like to thread popping out of the end, and the self adhesive foamy stuff I doubt would be deemed permanent.
I did sva and dont know much about iva so could be talking sh1te as usual, if I am please ignore me.
Rich
Gallery updated 11/01/2011
Yazza54
posted on 23/1/11 at 11:19 PM Reply With Quote
Another vote on changing the studs here, they look worryingly short. Everything else looks good.
I'm unhappy cos I eat and I eat cos I'm unhappy
adithorp
posted on 23/1/11 at 11:25 PM Reply With Quote
If those are slieve nuts then they go a long way down the stud and it's deceptive how many threads they're on. Tester might want to check the number of threads though. Mushroom insert securing is a regular one. The original shocks had a fin in the slot that secured on the pinch bolt for the same reason. Did it pass OK on the padding on the chassis? Rest looks good to me.
http://jpsc.org.uk/forum/
Davg
posted on 23/1/11 at 11:39 PM Reply With Quote
Yep with the above re the nuts, other point you will need to cover the top ball joint locknut, slit a bit of rubber hose should do.
cheers atb
D
Daddylonglegs
posted on 23/1/11 at 11:41 PM Reply With Quote
Another one for longer studs I'm afraid Sorry.
Dan.
posted on 23/1/11 at 11:49 PM Reply With Quote
thanks for posting, the odd bit of info for getting mine ready for iva
Davegtst
posted on 23/1/11 at 11:53 PM Reply With Quote
Whats with the diff mounts? Do they all need the plate on the back. Mine only has the 2 long bolts through it.
stevegough
posted on 24/1/11 at 08:21 AM Reply With Quote
As I said in the failure list thread, my Luego chassis came with the square plate - I naturally interpreted having the plate as the rear
mount for the diff, and fitted it as it was on the Sierra. IVA inspector picked up that I had only fitted two out of the four bolt holes and
demanded the other two. Most kit car builders use the front fittings only - and I'm sure a few guys who have passed would be happy to
confirm this
Luego Locost C20XE.
stevegough
posted on 24/1/11 at 09:04 AM Reply With Quote
Reply to comments.
First off, I've removed that mahoosive pic of the original wheelnuts as it was boogering up the thread!
Most of you have pointed out the wheelnuts not looking right - can see what you mean - the harsh shadows on the photo make it look worse than it is - as adithorp says though, they are pretty long nuts - I will count how many turns they are on later this morning and put it on here.
The bottom line is that the original wheelnuts (which were the closed-in type) were not a fail, only an 'advisory point' on the fail list. If he's not happy with these (which I think 'seat' better) I can always replace the originals.
RichardK (knobhead) - how do you rise to that dizzy status? - And adithorp - pointed out the foamy stuff - I presume you mean the bit I've put around the ends of the chassis tubes alongside the upper suspension brackets? It was on at the IVA, and David pointed out the susp brackets only - he never mentioned the foamy bit on the tubes - I think they are a good radius anyway - partly down to the immense thickness of the powdercoating!
Daveg - you are right - the tester did mention the front camber adjuster locknuts - he demonstrated that they aren't contactable with the 100mm 'knee' because of the wing stay - not too clear on that photo.
As usual, thanks for all your constructive comments - I'll go and have another look at the wheelnuts now.
Regards, Steve.
Luego Locost C20XE.
martyn_16v
posted on 24/1/11 at 09:14 AM Reply With Quote
It doesn't help at all, but I passed with no extra bolts threaded into my mushrooms and the VIN no in exactly the same place as yours. Go figure...
stevegough
posted on 24/1/11 at 09:23 AM Reply With Quote
Sounds like something we are all aware of, Martyn - consistant inconsistantcy. Like the DVLA! - Who is my next enemy.
Luego Locost C20XE.
stevegough
posted on 24/1/11 at 09:38 AM Reply With Quote
Just checked - there are 8 full turns on the front wheelnuts, and 11.5 on the rear.
Luego Locost C20XE.
monopoot
posted on 24/1/11 at 09:58 AM Reply With Quote
Just take some off cuts (half an inch) from a bolt with the same thread as the wheel nuts and screw them in the remaining thread of the nut. The tester will see some thread sticking out but not that it is a loose piece inserted there...
Daddylonglegs
posted on 24/1/11 at 10:17 AM Reply With Quote
Oooh! you naughty thing
stevegough
posted on 24/1/11 at 10:38 AM Reply With Quote
Good idea - as long as he doesn't ask me to unscrew one!
Luego Locost C20XE.
stevegough
posted on 24/1/11 at 12:02 PM Reply With Quote
Update - as I am not happy with the wheelnuts, just ordered some longer studs.
Luego Locost C20XE.
A1
posted on 24/1/11 at 12:44 PM Reply With Quote
i thought theyd revised the manual to say that the area within open front wheels were exempt from sharp edges?
posted on 24/1/11 at 12:51 PM Reply With Quote
Now now boys...
I had to do the mushroom retention thing to mine back in 2008 for SVA.
stevegough
posted on 24/1/11 at 06:00 PM Reply With Quote
I don't follow? The issue with the wheels is the wheelnuts, not sharp edges.
Luego Locost C20XE.
posted on 24/1/11 at 07:35 PM Reply With Quote
Surprised that the tester failed the steering column UJ for not having a locknut, Fords never fitted them on a Sierra. I modified my nose cone and put a bulge on either side to cover the front of the chassis.
wicket
posted on 24/1/11 at 09:40 PM Reply With Quote
Some useful info here about wheel nuts and thread engagement.
http://www.needforspeed.co.uk/htmlpages/TechWheels.htm
We had to remove a nut at the test to prove the thread engagement.
chunky2772
posted on 24/1/11 at 10:02 PM Reply With Quote
Im pleased ive seen the mushroom fix because i aint done that to mine (i had better get it done or that would be a fail for me!) thanks for that.
stevegough
posted on 25/1/11 at 01:09 PM Reply With Quote
The actual wording on the fail sheet was "steering column upper clamp bolts not using a locking device". The problem was the two bolts should have been secured by tabs (under the bolt heads) and these tabs had both broken off. My solution was to fit longer bolts, then secure with nylocs.
Interesting and useful information in that link there, Wicket - where is that info taken from? - my nuts are certainly more than the 6 turns - but as some others have pointed out, it looks bad - and the front wheels look even worse - you can hardly see the end of the bolt!
Luego Locost C20XE.
<<  1    2  >>
