Author: Subject: accessing busa standard ecu fault codes.. How?
:{THC}:YosamiteSam
posted on 29/1/11 at 07:21 PM Reply With Quote
how do you access the ecu fault codes on a busa? Do you need a set of bike dials from the bike the engine came from and a dealer mode switch? I havnt got issues with the car but one day you never know. Be nice to have the bits there if i need them. How is this all connected together?
bob tatt
posted on 29/1/11 at 07:36 PM Reply With Quote
as i understand it you need the standard clocks this gives you a rough idea of fault codes
chunky2772
posted on 29/1/11 at 08:45 PM Reply With Quote
Search for a member called (cosmick) he helped me with my gsxr 1000 he knows quite a lot about these suzuki engines send him a u-u.
what he dont know aint wort knowing!
interestedparty
posted on 29/1/11 at 09:21 PM Reply With Quote
If you've got the clocks you don't need the switch, it's a question of earthing one of the wires, the Haynes manual has the info you need (if you've got the clocks, that is)
chris taylor
posted on 29/1/11 at 10:37 PM Reply With Quote
Fault codes
You defo need the Busa clocks mate,
Chris
SJL
posted on 31/1/11 at 12:45 AM Reply With Quote
You can do it without the clocks search on the WSCC forum. I have previously posted on there how to do it in the Technical section.
http://www.ecueditor.com/
The above link will take you to the software you need
http://www.activeboard.com/forum.spark?forumID=99460&subForumID=392256&p=2
The above is the forum for the software
:{THC}:YosamiteSam
posted on 31/1/11 at 12:34 PM Reply With Quote
ok guys cheers. Will look into it
:{THC}:YosamiteSam
posted on 1/2/11 at 02:38 PM Reply With Quote
seems a 1999 engine is not accessible.. ah well maybe there is a way somehow
