Author: Subject: Sierra Rear Diff - Which Oil
spdpug98
posted on 9/2/11 at 09:45 PM Reply With Quote
I am just about to fit my new rear diffuser to the car and thought I would change the diff oil before I fit it, can someone confirm what oil I need to use (I did have it written down, but have lost it) and how much, is it up to the fill hole or is it a a litre
My Blog: http://spdpug98.wordpress.com/
daniel mason
posted on 9/2/11 at 10:02 PM Reply With Quote
i will try to find my haynes manual and u2u with the answer
hobbsy
posted on 9/2/11 at 10:48 PM Reply With Quote
It's just normal EP90 and a litre is just about enough - you have to make a dip stick yourself out a of bit of bent wire. It's supposed to be a few mm under the bottom of the fill hole (from memory - please check!)
posted on 9/2/11 at 10:50 PM Reply With Quote
GL-5 Hypoid Gear Oil EP80 or EP90 or EP 80w/90 or EP 75w/90
EP 80w/90 is probably the ideal choice.
spdpug98
posted on 10/2/11 at 03:58 PM Reply With Quote
Thanks for all the replies
