SandyC
posted on 10/2/11 at 11:15 AM |
C20XE oil filter stud
I've rebuilt my C20XE and am about to fit the oil filter, when i removed the oil filter stud from the 16v engine it had a hex on it and was
torqued up pretty tight, the stud i have from an 8v engine has no hex (no oil cooler) has no hex. So i can only use mole grips or something to tighten
it. Shold i loctite the stud in to the oil pump housing?
cheers
Tiger Avon
C20XE
bigrich
posted on 10/2/11 at 11:19 AM |
from memory has'nt it got a 10mm internal hex for an allen key?
SandyC
posted on 10/2/11 at 12:23 PM |
The one i took of with the oil cooler sandwhich plate had, but the new from from GM hasn't?
cheers
Tiger Avon
C20XE
JeffHs
posted on 10/2/11 at 01:56 PM |
Don't use Mole grips! Lock 2 nuts together and tighten the stud with the top nut, then unlock them.
