<<  1    2  >>
Author: Subject: SIDE REPEATERS on wheel arch
chesney321
posted on 19/2/11 at 10:22 AM Reply With Quote
went to pick up my lights and bodywork for my aries locoblade and steve said to wait for the side repeaters that fit on the front arches for a couple of weeks as he says the iva might change and make these fail the test all to do with the 5 degree rule as when you turn your wheels the lights may no longer be visable .dont know if this will happen but be careful.
Macbeast
posted on 19/2/11 at 10:33 AM Reply With Quote
I wish the goalposts would stay in one position for more than 2 minutes.
I don't understand why they won't accept two sets of side position indicators. On a 7, if we cant put them on the front wings and can't put them on the scuttle, where the hell CAN we put them ?
big_wasa
posted on 19/2/11 at 10:35 AM Reply With Quote
I am fed up with all the little changes. Only place left on a 7 will be the back arches then. I put mine there any way as there easier to wire.
Macbeast
posted on 19/2/11 at 10:39 AM Reply With Quote
But my back arches are too far from the front of the car ( 2m something )
Note 5: A side repeater lamp must be fitted within 2600 mm of the front of the vehicle
[Edited on 19/2/11 by Macbeast]
handyandy
posted on 19/2/11 at 10:50 AM Reply With Quote
I,ve just checked the IVA manual ( for M1 class vehicle ) & it states that the side repeater must be fitted within 2600mm from the front of the vehicle,
so, I,m fitting mine on the rear arches. ( A Haynes Roadster recently passed IVA with the side repeaters in this position).
cheers
andy
chesney321
posted on 19/2/11 at 10:51 AM Reply With Quote
steve reckons that the only place to put them would be beneath the scuttle on stalks that are long enough to be seen from front and rear but would look like s**t.just remove after the iva though.
handyandy
posted on 19/2/11 at 10:54 AM Reply With Quote
Not sure what the length of your car is.....
but, can you not fit the repeaters at the forward part of the rear arch? as long as the repeater is a minimum of 350mm from the ground & within 2600mm from the front then IMO it should pass the test ok, well, thats what I,m going for
cheers
andy
big_wasa
posted on 19/2/11 at 11:03 AM Reply With Quote
Stuff that I am going back to two wheels.
Mine are in the rear arches and are JUST within the 2600mm or what ever it is. Ive already had to put gromets in the scuttle to fill the holes for the last repeaters.
Ive only just changed my seat belts for the third time to keep up with the last revision before xmas of no longer allowing three point static belts. That was another £100 job
Thurbs
posted on 19/2/11 at 11:17 AM Reply With Quote
Well i've just put mine in the front arches !!!! fingers crossed.
I've spent more time trying to satisfy ridiculous IVA bull than I have putting the car together, I agree with the test as it keeps some dodgey kits off the road but i wish they could apply a bit of common sense.
Listen to me government agency and common sense get real !!!!!
Keep ploughing through the BS fellow IVA ers
Macbeast
posted on 19/2/11 at 11:41 AM Reply With Quote
I guess motorcycle stalks on the scuttle Ughh !!
I also had static belts and have had to buy new ones
stevegough
posted on 19/2/11 at 12:06 PM Reply With Quote
Maybe that's why they are called 'repeaters' Warren?
Mine are on the front of the rear arches - and they are 2350 mm from the front edge at that point. I didn't think these cars varied enough in dimensions to the extent where rear wheel arches fall outside the 2.6 metre point?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
big_wasa
posted on 19/2/11 at 12:14 PM Reply With Quote
Yep ive got the same repeaters, position is just a bit higher making them just a little further back.
http://i442.photobucket.com/albums/qq148/big_wasa/SDC10224.jpg
[Edited on 19/2/11 by big_wasa]
eddie99
posted on 19/2/11 at 12:33 PM Reply With Quote
Bollocks, well i guess by time i'll be ready for testing, IVA might have changed the rules back hahaa
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Mix
posted on 19/2/11 at 03:12 PM Reply With Quote
Hi
I suppose the way forward is to incorporate the repeater into the 'wing' mirror surrounds - shouldn't be too hard with the advent of LED flashers. Or is there a reason this would fail?
Regards Mick
Daddylonglegs
posted on 19/2/11 at 04:13 PM Reply With Quote
This is getting bl**dy ridiculous!
I've also put mine in the front wings just last week! I hope someone on here has an IVA before I'm ready, to see how they get on, I guess I better be prepared to move mine to the rear arches and do some filling on the front
BTW, car looks pretty nice Steve
[Edited on 19/2/11 by Daddylonglegs]
Michael
posted on 19/2/11 at 05:23 PM Reply With Quote
Mine are on the rear wings.
At IVA the first thing the tester said was oh good you read the manual.
He measured them later in the test though for the distance from the front, but i am sure he put a metal bar across front of front tyres and measured back but can not be 100% sure as i was removing boot cover for inspection in that area.
stevegough
posted on 19/2/11 at 05:35 PM Reply With Quote
BTW, car looks pretty nice Steve ...
Thanks, Dad!
Luego Locost C20XE.
posted on 19/2/11 at 06:26 PM Reply With Quote
Ironic when the front flashers are so badly positioned on many current German & French designed production vehicles.
gavin174
posted on 19/2/11 at 06:33 PM Reply With Quote
I went through IVA with the side reapeaters in the front headlights..
I think I posted a link on here before...
you can buy them now from SVC I believe
[Edited on 19/2/11 by gavin174]
Andybarbet
posted on 19/2/11 at 07:04 PM Reply With Quote
Im loving the repeaters in the headlight bowls idea, its spot on
Thats what im going to do now.
loggyboy
posted on 19/2/11 at 10:50 PM Reply With Quote
Exactly what I was planning to do.
aka_shortie
posted on 20/2/11 at 12:16 AM Reply With Quote
If you have already fitted them up front, can you not just leave them and add the extra ones on the rear arch or is that breaking another rule?
Thurbs
posted on 20/2/11 at 12:30 PM Reply With Quote
Yep your only allowed one set of repeaters
Macbeast
posted on 20/2/11 at 01:20 PM Reply With Quote
Which is really stupid
aka_shortie
posted on 20/2/11 at 10:36 PM Reply With Quote
some of the rules / regs make no sense to me.
Surely mounting them on the rear arch makes them less visible. Especially at junctions?
<<  1    2  >>
