Author: Subject: Add/Remove programs problem.
posted on 4/7/04 at 08:41 PM Reply With Quote
I have a winfast program with a problem and tried to remove it with control panel so I can reinstall it but I keep getting a warning from spybot that it is terminating a process listed as part of a malicious software called funwebproducts. I have searched the hard drive for it and it doesn't show up. It shows the filename as set38.tmp but it keeps reappearing with different numbers after the set**.tmp bit. Any suggestions how to nail it down?.
[Edited on 4/7/04 by Peteff]
ady8077
posted on 4/7/04 at 09:04 PM Reply With Quote
Hi Pete
Have you tried restarting in safe mode? It sometimes stops programs running at startup
Adrian
gjn200
posted on 4/7/04 at 10:12 PM Reply With Quote
Search for all .tmp files and delete em' all!! It wont hurt anything as they are temporary files.
<- Me!
simonH
posted on 5/7/04 at 06:50 AM Reply With Quote
anti spyware software
try using "Spybot S'n'D " or lavasofts ad-aware you often need both as they each sometimes miss some items
http://www.spybot.info/
http://www.lavasoft.de/
hope that helps
posted on 5/7/04 at 08:43 AM Reply With Quote
Got both of them and hijackthis. It's something disguised as a system file and it keeps changing its name every time you start up. I took it out of registry and everything manually but it's back. Housecall recognises it as QDIAL16, it also finds BYTEVER but can't remove them.
simonH
posted on 5/7/04 at 09:08 AM Reply With Quote
QDial is a trojan. update your AV
Trojan Information
Discovery Date: 10/27/2003
Origin: Germany
Length: 6144 bytes or
8192 bytes
Type: Trojan
SubType: PornDialer
Minimum DAT: 4300 (10/29/2003)
Updated DAT: 4333 (03/03/2004)
Minimum Engine: 4.2.40
Description Added: 03/16/2004
Description Modified: 03/16/2004 8:11 AM (PT
Benzine
posted on 5/7/04 at 10:44 AM Reply With Quote
Whenever i have a problem i use Tech forum You can post your script from hijack this and they'll tell you whats wrong and how to fix it.
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make it moral.
