<<  1    2    3  >>
Author: Subject: 0-100 in under 10 - whats needed?
franky
posted on 21/2/11 at 02:48 PM Reply With Quote
I've been having a good discussion at work about whats needed for a sub 10 second 0-100. All this was started when people asked 'how fast is my car going to be'. I said I haven't got a clue and that what ever car it is is limited by traction more than anything, I guess launch/traction control/rubber will help here.
What sort of engine/weight/configuration combo is needed? or what cars on here will do it? A Middy must be good due to the extra weight over the driven wheels I guess?
omega0684
posted on 21/2/11 at 03:06 PM Reply With Quote
i bet a a BEC with a hairdryer on it could do it
bigrich
posted on 21/2/11 at 03:08 PM Reply With Quote
http://www.letstorquebhp.com/calculator.asp
try this, 250bhp in a 700kg rwd car should do it
StrikerChris
posted on 21/2/11 at 03:10 PM Reply With Quote
Pretty sure mine could but obviously its never been over 70!About 200horses and fairly light 7 should be near without traction controll etc in my opinion!
mcerd1
posted on 21/2/11 at 03:18 PM Reply With Quote
or 180bhp with 500kg
or 300bhp with 1000kg
if you beleve that site
Mr G
posted on 21/2/11 at 03:24 PM Reply With Quote
A high cliff
franky
posted on 21/2/11 at 03:25 PM Reply With Quote
I'm not sure I do.... the brick wall areodynamics we have might have some effect getting on for those speeds, eating a few HP.
I can remember in one mag years ago where a car was quicker with 2 people in due to the extra weight over the rear.
sorens2
posted on 21/2/11 at 03:47 PM Reply With Quote
I think mine does. Or its pretty close.
190 bhp and 490 kg.
ZX12 and I think 4th gear is 160 km/h
http://www.youtube.com/watch?v=oN_45MHerYw
Soren S2
flak monkey
posted on 21/2/11 at 04:06 PM Reply With Quote
Mine would do it comfortably. 291bhp, 520kg.
A shade under 3 sec to 60mph and another 4sec to 100mph so 7secs
Otherwise have a look here:
http://www.strikeengine.com/performance-car-specs-0-60-0-100-power-weight-top-speed.html
and
http://www.torquestats.com/index.php?pid=mph100
Loads are listed.
Sera
http://www.motosera.com
franky
posted on 21/2/11 at 04:21 PM Reply With Quote
and
Loads are listed.
Did you test it properly 0-100? Its got me thinking of what mine might be like too.
rodgling
posted on 21/2/11 at 04:45 PM Reply With Quote
I don't think that site is much use because it doesn't take into account the high torque of your engine - your car is going to accelerate hard from 2000 - 8000 rpm, not just in a narrow 2-3000 rpm powerband.
I think the only real answer is to buy some sticky tyres, take it to a track and find out. But to get your best possible time, you're going to have to be willing to abuse your clutch, which makes it all a bit academic.
blakep82
posted on 21/2/11 at 05:08 PM Reply With Quote
that letstourquebhp site is total mince. doesn't take into account any aerodynamics of the car, and especially GEARING,
for a 700kg car, 200bhp, it reckons it'll do it in 10.75 sec.
great, but supposing i have a crap gearbox with a 5th gear with a 1.5 ratio, and a 3.44 diff. i can only manage 92mph accourding to gearcalc.
total nonsense
________________________
cloudy
posted on 21/2/11 at 05:31 PM Reply With Quote
R4 will do it pretty comfortably in 10, 170hp/~350kg (just under 7 to 100) you don't need mega power just loose that weight!
James
www.warnercars.com
flak monkey
posted on 21/2/11 at 06:23 PM Reply With Quote
Yep FWIW I datalogged it just before I sold the car
0-60 2.9 sec (2nd)
30-50 0.9sec (2nd)
50-70 1sec (3rd)
60-100 4 sec (4th)
Sera
franky
posted on 21/2/11 at 06:47 PM Reply With Quote
0-60 2.9 sec (2nd)
30-50 0.9sec (2nd)
50-70 1sec (3rd)
60-100 4 sec (4th)
Cool. What did you use to log it? Thats a quick car!!!
Dave, its a new clutch(well 2k old) so it should take some abuse. The racelogic should do the rest, you'll know well before me
flak monkey
posted on 21/2/11 at 06:55 PM Reply With Quote
My dash had a built in datalogger. Aim MXL Pro
Sera
daniel mason
posted on 21/2/11 at 06:58 PM Reply With Quote
Am hoping mine will get close! What's the caterham r500's time? Am sure it's about 8 seconds
RazMan
posted on 21/2/11 at 07:31 PM Reply With Quote
My Evodash tells me 0-60 is 1.9 secs ......... if I spin the wheels coz it's speedo sensor is in the gearbox
Raz
dlatch
posted on 21/2/11 at 07:39 PM Reply With Quote
franky
i think your car would be capable of doing a 10 something sec 1/4 mile
there is a "if" though........ perfect Launch
russbost
posted on 21/2/11 at 08:04 PM Reply With Quote
Well if you lot put the engine at the right end you'd find it much easier!
Sure the new Furore will do it easily tho' haven't found any dry roads to check on as yet!, 190BHP 113 ft/lbs (times the torque multiplier b4 the gearbox for a fair comparison!) ZZR1400 in 560Kgs
James (Cloudy) surely your car can't really be sub 350kgs??? Where have you had that weight checked (I've had variations of over 250kgs from IVA stations for very similar cars - gives you great confidence in their equipment & measuring techniques!!!)
cloudy
posted on 21/2/11 at 08:25 PM Reply With Quote
I'm pretty sure it's within 25kg of that - I used the 4 bathroom scale method - hence the ~ !
The fact I can pick the front of the car up and it's logged performance does seem to verify those measurements however
James
www.warnercars.com
franky
posted on 21/2/11 at 08:42 PM Reply With Quote
Is it a GPS logged figure though? or just wheel speed on a ETB dash?
cloudy
posted on 21/2/11 at 08:48 PM Reply With Quote
Both, I calibrated my ETB by GPS comparison - but I do have a 10Hz gps device
James
www.warnercars.com
flak monkey
posted on 21/2/11 at 08:54 PM Reply With Quote
My datalogged times are wheel speed timed without wheel spin.
Sera
chris mason
posted on 21/2/11 at 09:10 PM Reply With Quote
Franky, with the m3 power you'll breeze it, My old s2000 powered Mk indy did 110mph in 12.1 and went through the 1/8 trap at 92mph in 7.7 seconds, so i'd say 230bhp in a cec is enough to do 100mph in 10 seconds
My current car takes approx 500bhp to do it, but then it does weigh just shy of 2 ton
[Edited on 21/2/11 by chris mason]
<<  1    2    3  >>
