mads
posted on 26/2/11 at 10:53 PM |
where can i get joint covers for tripod driveshafts from?
we were about to dismantle the tripod rear driveshafts i've got and when looking in the haynes manual, it says to cut the joint cover with a
hacksaw, thus needing a new one. have looked on the net for these but can't find them. rang local motor factors who came up with nothing other
than offering refurbed driveshafts.
so where can i get these from? i dont mean the rubber gaitors but the metal cover that goes over the bearing housing.
you must be able to get them from somewhere if there are companies refurbing driveshafts. refubred driveshafts are £70+ a side!
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
austin man
posted on 26/2/11 at 11:03 PM |
you can get kits from ebay which stretch over the CV joint they are universal fitting and come with a cone that you stretch the rubber over. I can
recomment them as this ids what I have fitted to 4 shafts to date. You do need a good grip and to use s bit of elbow grease to stretch them over the
joint
LARGE UNIVERSAL STRETCH CV JOINT BOOT & FITTING CONE on eBay (end time 04-Mar-11 18:43:14 GMT)
[Edited on 26/2/11 by austin man]
deezee
Did you try Ford?
mads
posted on 26/2/11 at 11:06 PM |
joint
thanks but those are the gaitors, not the metal joint covers i am after.
bbwales
posted on 27/2/11 at 01:06 AM |
I managed to get a full set from my local Ford dealer, comprised of the metal covers, the rubber boots and the clips to hold the boots onto the shaft
and cover.
Try speaking to Ralph (stores) at Evans Halshaw in Wrexham 01978 365585
Regards
Bob
Flamez
posted on 27/2/11 at 06:08 AM |
You can remove them by using a small chisel on the the lip and replace by using a ball peon hammer to reseal. There are o rings inside that make the
seal.
my build mac1motorsports
snapper
posted on 27/2/11 at 07:20 AM |
Ford parts department.
I eat to survive
I drink to forget
dave
posted on 27/2/11 at 09:53 AM |
Is this what you are looking for
Linky
Westfield will sell you the individual parts shown.
mads
posted on 27/2/11 at 10:21 AM |
cheers folks. just rang them but parts department is closed.
Dave - those are for the bolt-on driveshafts, but I'm after the push-in ones. Thanks anyway though
