Author: Subject: prop catcher
brookie
posted on 27/2/11 at 01:06 PM Reply With Quote
prop catcher
as above any body got a photo off one fitted to an mk
RichardK
posted on 27/2/11 at 01:13 PM Reply With Quote
Doesn't really have to be specific to a manufacturer, here is a design I saw that I really liked
Linky
Rich
Gallery updated 11/01/2011
snapper
posted on 27/2/11 at 01:21 PM Reply With Quote
A couple of extra tubes before the UJ's should be fine, the idea is to contain the prop after the UJ has sheared to stop it flailing about and coming through the tunnel sides.
Some thick sheets of steel would also work.
I eat to survive
I drink to forget
Strontium Dog
posted on 27/2/11 at 01:24 PM Reply With Quote
I'm with Richard. That has to be the best way to do it I've seen so far. Simple and effective and removable easily!
MK9R
posted on 27/2/11 at 01:47 PM Reply With Quote
Ow about this for simple, just an old centre prop bearing with bearing and rubber removed
h
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Mix
posted on 27/2/11 at 01:50 PM Reply With Quote
Hi
Whilst I fully agree with the installation of 'prop catchers' and the one referenced by Richard is a fine example, I would urge anyone who has fitted / intendes to fit one to check the prop shaft after some spirited driving. Flex in the chassis may allow the prop to contact the catcher and wear the shaft at this point. If this goes un noticed it could lead to failure of the shaft in a manner which may not be contained.
Regards Mick
