Author: Subject: Nice & simple header tank!
PuppiesBalls
posted on 3/3/11 at 01:27 PM Reply With Quote
Good afternoon gents!
I need a pair of expansion tanks, does anybody know where i can get them from?
The need.....
pressure cap, because the rads dont have them
1x15mm ish drain at the bottom,
3x8mm ish pipes on the side, 2 near the the top, and 1 near the bottom
Looked on ebay theres nothing which suits
They will both be mounted next to each other so need to be symmetrical really
nib1980
posted on 3/3/11 at 01:39 PM Reply With Quote
have you tried alloy fabrications?
imp paul
posted on 3/3/11 at 01:40 PM Reply With Quote
give james a call at alloy racing fabs he would make you a pair tell him i told you to call him cheers paul
blakep82
posted on 3/3/11 at 03:05 PM Reply With Quote
2 mounted next to each other? interesting
yep Jim at alloy racing fabrications is your man
________________________
posted on 3/3/11 at 04:19 PM Reply With Quote
Unless you have two engines with separate rads only use 1 tank 1 pressure cap or you will get airlocks, normal plumbing is:
Air bleed from cylinder head(s) and top of rad T'eed together in to the top expansion tank.
Return from bottom of header tank to bottom hose or bottom of radiator.
[Edited on 3/3/11 by britishtrident]
PuppiesBalls
posted on 3/3/11 at 04:26 PM Reply With Quote
thanks guys, the second rad is for a charge cooler setup, 1 rad & header for engine
posted on 3/3/11 at 07:27 PM Reply With Quote
I have one that fits your description, came off a shiny newish (bent) Corsa in the scrappy.
