joemotion
posted on 4/3/11 at 04:14 PM |
Sierra driveshaft wanted!!
Im after sierra push in driveshafts however need the following spec - diff end 28mm diameter with 26 teeth. total length 84cm. This is the drivers
side shaft which is the longer one.
I bought the wrong ones recently so have them up for sale separately
Does anybody know the model which these are from as cant be certain that they are the ones from the donor which was a 1.8 LX 1988
All help appreciated!
austin man
posted on 4/3/11 at 08:16 PM |
is it smaller diameter than usual if so I was led to believe these were from the 1.3 or 4x4 I have the small ones fitted the shaft is thinner also
joemotion
posted on 4/3/11 at 08:25 PM |
the ones i have bought in error were smaller - 23 teeth 25mm in diameter
im after the larger one with 26 teeth and 28mm in diameter
james jones
posted on 12/3/11 at 12:35 PM |
shafts
hi i think i have the joints and shafts you are after , i bought them in error ,you can call me on 07949088228, cheers JIm.
theduck
posted on 12/3/11 at 12:55 PM |
Will have a look for you in a bit, may have a suitable pair.
