Author: Subject: Wanted : MX5 TorSen LSD -
55ant
posted on 8/3/11 at 07:34 PM Reply With Quote
Willing to collect from just about anywhere
must be the torsen diff not the viscous one (viscous found in 1.6 models i think)
Cheers, Ant
away from cars, now cycling and building TT bikes
MakeEverything
posted on 8/3/11 at 07:45 PM Reply With Quote
Cheers, Ant
Where've you been man!?
http://www.locostbuilders.co.uk/viewthread.php?tid=149032
[Edited on 8-3-11 by MakeEverything]
Kindest Regards,
Richard.
BigLee
posted on 8/3/11 at 07:46 PM Reply With Quote
Is it 1.8 or 1.6 you're after as some import 1.6's had the LSD. 1.8 is bigger in body than the 1.6, and the prop-shaft flange is a slightly different size (as I discovered to my cost!)
They tend to fetch good money amongst the MX-5/Miata/Eunos tuners.
55ant
posted on 9/3/11 at 07:17 PM Reply With Quote
Hi guys, ah been busy with the other hoby of triathlons, so mainly cycling and spending far to much money on very small peices of carbon fibre.
Will be sorting out a day in may hopefully!
its the 1.8 im after, 1.6 LSD are usualy the viscous diffs, I have seen the price the LSD 1.8's go for, its crazy, im quite tempted to go all drifty and have my open diff welded, not sure at the moment.
will be lurking round quite a bit now though!!! so if you lot break any mx5's let me know!
