Author: Subject: Ooops
dave
posted on 13/3/11 at 09:50 AM Reply With Quote
Ooops
Guess who didnt put anti freeze in the coolant system. Fortunatley this is the only damage.
posted on 13/3/11 at 09:58 AM Reply With Quote
It's Evolution Baby!
adithorp
posted on 13/3/11 at 10:02 AM Reply With Quote
Lucky to get away with it if thats the only damage. Check all the core plugs haven't moved. Always use anti-freeze/coolant. It's anti-corrosive and lubricant properties means it does move than just stop freezing.
http://jpsc.org.uk/forum/
tomgregory2000
posted on 13/3/11 at 10:05 AM Reply With Quote
i guess you!
posted on 13/3/11 at 10:14 AM Reply With Quote
It also improves the heat transfer so it aids cooling in summer. That's why the full title is usually "anti-freeze and summer coolant"
It's a good thing (unless you drink it ).
MakeEverything
posted on 13/3/11 at 10:50 AM Reply With Quote
Wasnt it used in bootleg wine at some point?
Kindest Regards,
Richard.
richardlee237
posted on 13/3/11 at 10:59 AM Reply With Quote
Ethylene glycol Anti freeze actually has a detrimental effect on the cooling capacity.
see extract below from Engineering Toolbox website
Note! The specific heat capacity of ethylene glycol based water solutions are less than the specific heat capacity of clean water. For a heat transfer system with ethylene glycol the circulated volume must be increased compared to a system with clean water.
In a 50% solution with operational temperatures above 36 oF the specific heat capacity is decreased with approximately 20%. The reduced heat capacity must be compensated by circulating more fluid.
Automobile antifreeze solutions should not be used in HVAC systems because they contain silicates that may cause fouling. Silicates in automobile antifreeze are used to protect aluminum engine parts.
Note! Distilled or deionized water should be used for ethylene glycol solutions.
Quote Lord Kelvin
“Large increases in cost with questionable increases in performance can be tolerated only in race horses and women.”
Quote Richard Lee
"and cars"
bi22le
posted on 13/3/11 at 11:10 AM Reply With Quote
My mate split the block on his newly rebuilt £2K rover V8 because of this. It goes with out saying he was upset!
I dont understand why people dont put anti freeze in out of principle.
Please read my ring story:
LoMoss
posted on 13/3/11 at 11:18 AM Reply With Quote
Should have kept it in Pats garage like I did. 20'c for 24/7 you dont need any anti freeze.
Moss
