Author: Subject: High idle
chris666
posted on 13/3/11 at 05:12 PM Reply With Quote
High idle
Good evening guys,im tearing my hair out trying to work out why the engine idle when warm is 1200 rpm,shouldnt it be around 900 ish?And how would i go about turning it down?im running black top zetec,jenvey throttle bodies,mbe ecu.
Ive got a laptop and easimap software available.
I think ive read something a while ago about adjusting the timing,Not sure how i would do this.
Any help please!
Chris
norfolkluego
posted on 13/3/11 at 05:21 PM Reply With Quote
Who you calling idle
perksy
posted on 13/3/11 at 06:28 PM Reply With Quote
Could be a few things tbh
Is the TPS set correctly and does its voltage correspond with that in the map ?
Has it always been like this or is this something that has just started to happen ?
Danozeman
posted on 13/3/11 at 06:36 PM Reply With Quote
do the butterflies close properly on the throttle bodies?
Dan
chris666
posted on 13/3/11 at 06:39 PM Reply With Quote
How do i set the tps up properly?Its always been like that.
The butterflys are shut fully.
Cheers Chris
posted on 13/3/11 at 06:55 PM Reply With Quote
Balance throttle bodies, air leaks ,no slack in throttle linkage,twisted throttle shafts, butterflies not centralised in throttle bodies, over advanced ignition timing can all cause a fast idle
RazMan
posted on 13/3/11 at 07:47 PM Reply With Quote
You are probably leaking air past the butterflies. You will need to closely inspect them against a light source to see if there are any leaks. If you cannot achieve a perfect seal then you can try retarding the ignition in the map - I have reduced my idle this way.
Raz
