kensprin
posted on 14/3/11 at 12:30 AM |
Tacho
Just got my hands on a 4cyl smith Tacho to run on my v6 cossy. would it work stright off edis 6 pin 2 or would I need todo the zener diode trick off
the coil pack? would it work at all.
Its in the post but im losing sleep over it.
Macbeast
| posted on 14/3/11 at 06:00 AM |
Not sure that a 4-cyl tacho could be adjusted to run off a 6 cyl engine. Maybe not what you wanted to hear
deezee
| posted on 14/3/11 at 09:11 AM |
I'm not sure its going to work. Wouldn't your engine fire 6 spark plugs in 2 revolutions? but the tacho is calibrated for only 4 signals
over 2 revolutions. So its going to read 50% higher?
[Edited on 14/3/11 by deezee]
| posted on 14/3/11 at 10:09 AM |
As said it would read 50% too high. You could get the tacho recalibrated (or do it yourself if you have some electronics knowledge), but this will
involve taking the tachometer apart and changing a component.
