Author: Subject: Dellorto 45s vacum advance???
SandyC
posted on 15/3/11 at 10:07 PM Reply With Quote
I'm in the midst of changing out my pinto for a red top. I'm going to run the red top with an MBE ignition and the 45's from my pinto. Question is the pinto had a dizzy with the vacum advance going into one of the 45's, what do i do with hose going in to the carb? Take it off and blank it?
thanks in advance for any help
Sandy
Tiger Avon
C20XE
imp paul
posted on 15/3/11 at 10:13 PM Reply With Quote
you could blank it off as long as you don't need a vac take off for any thing on your new set up hope this mite help cheers paul
austin man
posted on 15/3/11 at 10:14 PM Reply With Quote
put a bolt into the pipe and jubilee clip
norfolkluego
posted on 16/3/11 at 12:14 AM Reply With Quote
Why would you need vacuum advance with electronic ignition (sorry if that's a daft question)
snapper
posted on 16/3/11 at 05:22 AM Reply With Quote
To sense engine load the electronic ignition will use a manifold actual pressure sensor (MAP) which needs to see vacuum from all 4 runners or throttle position sensor (TPS) which would be a reostat mounted on the throttle butterfly rod.
Some crude ECU's may only need to see the engine revs but that would provide a 2D ignition map only.
[Edited on 16/3/11 by snapper]
I eat to survive
I drink to forget
posted on 16/3/11 at 09:06 AM Reply With Quote
If you had the vac advance plumbed off one of the chokes on the Pinto carbs then the ignition timing must have been jumping around something awful.
