Author: Subject: how do you reset fault codes R1
tony@signtek.net
posted on 23/3/11 at 11:00 PM Reply With Quote
Hello All
Dropped a clanger!!
removed plugs on my R1 5pw and tested starter motor start button immediately induced fault code 11 on clocks evidently something to do with cam position sensor which verifies and synchronises firing order etc then replaced plugs and coils thinking fault would sort itself out
Alas it did not
Have checked coils are on correct cylinder
Is it necessary to reset clocks to get rid of fault code?
If so how
before this ill advised test all was well!!!
Tony
nitram38
posted on 24/3/11 at 06:12 AM Reply With Quote
Have you tried simply disconnecting the battery for a while and trying again?
adithorp
posted on 24/3/11 at 09:26 AM Reply With Quote
It resets itself at next start up if the fault has gone. If you've still got thecode the fault is still there. Have you checked the sensor and plug?
http://jpsc.org.uk/forum/
afj
posted on 24/3/11 at 09:27 AM Reply With Quote
the r1 clocks reset every time the ignition is switched if its still flagging a fault after the engines running for a few seconds or the ignition is switched on after a few seconds then there is still a fault
beaten to it
[Edited on 24/3/11 by afj]
eerrrrrrrrrrrrrrrr
