Author: Subject: Megasquirt and Tacho driving - opinions please
adrianreeve
posted on 26/3/11 at 07:00 AM Reply With Quote
As far as I can see, there are two ways of driving a traditional coil driven tachometer if you have megasquirt:
1. Use the tacho output from the 'squirt, and add a relay coil in line to provide a voltage spike (as per extra efi website)
2. Use a tacho driver made of 3 diodes to directly drive the tacho from the coil pack, no connection to the megasquirt required. (Trigger wheels sell one for £10)
Which method have you chaps used / would you recommend?
Adrian
snapper
posted on 26/3/11 at 07:17 AM Reply With Quote
I have used the 3 diodes off a coil pack, this worked without issue.
I have used the Tacho out from the EDIS no problems.
I am now using Megajolt Tacho out on a Smiths electronic
I eat to survive
I drink to forget
matt_gsxr
posted on 26/3/11 at 07:43 AM Reply With Quote
I have a coil (like the relay solution) driven from the low tension side (just one ignition output on my wasted spark system). This gives the right number of pulses for my Aprilia rev counter.
I set it up this way as previously I was using the stock suzuki CDI, and haven't changed it.
SPYDER
posted on 26/3/11 at 01:56 PM Reply With Quote
I used method one. No problems.
scudderfish
posted on 26/3/11 at 05:07 PM Reply With Quote
I used the relay method, but the buzzing annoyed me as the relay was behind the dash and not in the engine bay. I now drive my tacho off my EDIS module.
paulf
posted on 26/3/11 at 10:01 PM Reply With Quote
If you have an Edis then the pip signal sometimes works better than the tacho output on some rev counters, i have mine connected up like this and the smiths type tacho works reliably .
Paul
adrianreeve
posted on 27/3/11 at 02:44 PM Reply With Quote
No edis, so I think I may go for the diode option.
Adrian
scudderfish
posted on 27/3/11 at 04:11 PM Reply With Quote
My tacho just packed up Time to fiddle with the wiring again....
DaveFJ
posted on 28/3/11 at 12:18 PM Reply With Quote
i went for the diode option.. a few cheap parts from maplins and a few mins with a soldering iron - jobs a good'n
Dave
austin man
posted on 31/3/11 at 08:45 PM Reply With Quote
any chance of a diagram and detail of parts I have an acewell with Tacho which reads a little sporadic and a seperate 52 mm gauge which reads wrongly so im going to have to do someting. I have megajolt and EDIS fitted
Snuggs
posted on 3/4/11 at 10:36 AM Reply With Quote
Megajolt has a Tach Out that normally works.
U have U2U
Clive
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
