Author: Subject: Fog light regs.....confused
Dickyboy
posted on 27/3/11 at 09:06 AM Reply With Quote
Just checking wiring functions pre IVA and:-
The rear fog works only when the headlights, dipped or main, are on, as per book, but I have it so the ignition has to be on as well, just re-read the IVA spec and it seems to say whenever the headlights are on the foglight should able to be on. Anybody got any idea what the rules are> On our tintop the headlights only come on with ignition on so can't use that as a test!
[Edited on 27/3/11 by Dickyboy]
big_wasa
posted on 27/3/11 at 09:24 AM Reply With Quote
fog needs to be able to switch on with main or dip but not just side. Side needs to be able to turn on with or with out ignition on. Dip and main just with ignition on.
Thats how I read it.
stevegough
posted on 27/3/11 at 07:31 PM Reply With Quote
Don't get hung up on this. The IVA regs state that the fog must only come on if main or dip are on. The regs say nothing about ignition either on or off - so it doesn't matter. As long as it can't be switched on when the headlights are off - you are complying.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
mad-butcher
posted on 29/3/11 at 07:20 PM Reply With Quote
and there is a tell tale lamp, on the dash ? correctly marked of course
