Author: Subject: Running a PAS rack dry - likely damage?
alistairolsen
posted on 31/3/11 at 01:23 PM Reply With Quote
If I was to drain the majority of the fluid from a hydraulic PAS rack by moving it to the end of its travel in both directions, and then seal the ports with a loop of pipe between them so it can breathe, would it be likely to cause any damage for a few hundred miles?
My Build Thread
Chippy
posted on 31/3/11 at 02:26 PM Reply With Quote
I would think that it will be fine, just make sure that it's well greased up. Not too sure that you need to remove the fluid though, just fit a loop of tube between the two feed holes. HTH Ray
deezee
posted on 31/3/11 at 02:31 PM Reply With Quote
Just a rack would be fine. The power steering pump normally suffers problems though if its left empty of fluid.
hughpinder
posted on 31/3/11 at 03:01 PM Reply With Quote
When the fluid pipe on my rover 820s power steering burst, I just disconnect the belt to the PAS pump and drove it without the assistance (for about 3 months) - but it was only ever going to go to the scrappies from that point anyway.
Hugh
big-vee-twin
posted on 31/3/11 at 03:42 PM Reply With Quote
I had a Freelander that I destroyed the pump and the rack due to no oil
http://www.triangleltd.com
posted on 31/3/11 at 04:04 PM Reply With Quote
Hugh
Why didn't you just loop the hoses together I've done it a few times when the loop of pipe that acts as a cooler corrodes --- works fine in the uk climate
alistairolsen
posted on 31/3/11 at 04:20 PM Reply With Quote
Im converting to PAS, but I cant find the required mount so I plan to install the rack and new front suspension but not fit the pump at all yet....
My Build Thread
posted on 31/3/11 at 07:31 PM Reply With Quote
Not sure it would be legal to drive on the road without the pump and pipes etc???
posted on 1/4/11 at 11:27 AM Reply With Quote
MOT failure but beyond that ?
Mr Whippy
posted on 1/4/11 at 12:01 PM Reply With Quote
done it and no damage to either the electric pump or the rack
blakep82
posted on 1/4/11 at 12:10 PM Reply With Quote
thought it was 'possible' to drive with the pump drive belt removed, so still full of fluid and it would be fine?
however, sure its a MOT failure, as you essentially have inoperative steering. as a power steering system, its simply not working. steering is a pretty important part.
also, PAS racks are not manual racks wich have been adapted to provide power assistance, but are a completely different design internally, and will give VERY heavy steering if not powered. i'd find a manual rack for now, until you find the mounts you need for the pump
________________________
bimbleuk
posted on 1/4/11 at 01:15 PM Reply With Quote
Done quite a bit on the RX7 V8 conversions. For a permanent conversion on those there are a couple of oil seals inside the rack which can be removed to reduce the resistance. Also the pinion assemble is welded to remove some slop in the oil control valves which is usually taken up with the oil under pressure.
Not my personal preference, on a heavy tin top anyway.
