Author: Subject: New Wideband Controller?
posted on 10/4/11 at 11:24 AM Reply With Quote
I've never been able to connect my lappy to the LC1. I've tried a desktop and wor lasses new netbook. Nowt.
I'm considering a new controller so I can see what's happening. Which is best/cheapest to use with my wideband Bosch sensor and Innovate gauge?
woolly
posted on 10/4/11 at 07:51 PM Reply With Quote
unless the LC1 is faulty you will struggle to get another to work.
most common connection problem is the serial to usb converter drivers.
RazMan
posted on 10/4/11 at 08:04 PM Reply With Quote
Are you sure you are connected to an engine earth? They are very particular about this.
Raz
posted on 10/4/11 at 08:51 PM Reply With Quote
No usb, and all the earths go to th block.
Just to say, it does work, just can't get in to see what the outputs are. I want to double check to make sure the Omex is getting a correct signal.
