Author: Subject: ZX10 engine
mattyc
posted on 10/4/11 at 06:04 PM Reply With Quote
ZX10 engine
For sale is 1no. ZX10B (the late 1980's one) engine all the of the bit's from the bike to get it running which are:
Engine itself - probably the cleanest old ZX10 engine you'll ever see! s/steel bolts to all the casings etc etc. I was told it's done about 30,000 miles and having had a look inside I have no reason to doubt it!. All engine numbers present and correct
Carbs and original airbox - carbs have the ZXR750 tops which de restrict the engine to about 137bhp
The sump and oil pickup pipe on the engine is a gpz900r one which fits perfectly and is much shorter than standard. The standard sump and pickup pipe are in one of the boxes though
There are two water pump covers, one zx10, one zzr1100 which both fit but have the outputs facing in different directions so choose the one that suits your installation
M/S exhaust headers from the bike
Full Wiring loom and clocks
ZX10 radiator with fan
Starter motor and alternator, the alternator is a zzr1100 one with new cush rubbers
Prop adaptor
Clutch lever and master cylinder with braded stainless steel hose
Looking for £350.00
mattyc
posted on 12/4/11 at 05:35 PM Reply With Quote
Sorting out other bits and bobs I have to go with it are a Haynes manual and gear indicator.
coyoteboy
posted on 12/4/11 at 07:29 PM Reply With Quote
All the bargains are miles away, as ever.
mattyc
posted on 12/4/11 at 08:12 PM Reply With Quote
I can palletize it for you
mattyc
posted on 16/4/11 at 06:28 PM Reply With Quote
going on the bay of e soon just found the new plugs and oil filter for it and a spare set of carbs for spares
mattyc
posted on 18/4/11 at 08:42 AM Reply With Quote
Now on ebay Item number: 290556668376
jossey
posted on 18/4/11 at 10:30 AM Reply With Quote
good luck.
love the engine. i was lucky to pick up a engine only to replace my dead zzr.
David Johnson
mattyc
posted on 23/4/11 at 06:14 PM Reply With Quote
Reduced to 300quid to clear!
mattyc
posted on 4/5/11 at 09:24 AM Reply With Quote
Bump!
twybrow
posted on 4/5/11 at 12:19 PM Reply With Quote
Bargain! Someone must need a bike engine!?
capri_big_jim
posted on 4/5/11 at 12:32 PM Reply With Quote
You never did send me the engine dimensions mate...
