Author: Subject: Prop angle
peteday_uk@btinternet.com
posted on 11/4/11 at 09:59 PM Reply With Quote
Prop angle
Hi.....I need help
What is the minimum angle needed to allow the prop joint/uj to have load on them for a bike engine car. At the moment the reverse box centre sits about 5mm above the diff centre, is this enough to put load on the UJ's?
All the best
Pete
Bluemoon
posted on 12/4/11 at 08:02 AM Reply With Quote
Take a look at:
http://www.locostbuilders.co.uk/viewthread.php?tid=145955
Remember the angle is not just in one plane (up and down) but also sideways as well if you see what I mean.. Can't comment on 5mm the angle depends on prop length as well as the 5mm you mention..
Dan
